strange texture
  • egalecki
    • Mar 2008
    • 1049
    strange texture
    I've been fooling around with different whole wheat flours. This week it's Hodgson's Mills whole wheat. I made the wild yeast starter in Whole Grain Breads last night for my bread today- and it was not the same texture at all that I am used to. It was quite wet, for one thing. I couldn't get the same feel in the dough at all. I did add some more flour, but I decided to wait and adjust some more today if needed.
    Well, the starter/biga was still quite wet this morning. I added it to the soaker and put it in the mixer, and I had to add a LOT of flour to get the texture anywhere near correct. It's risen ok and is in the wfo now, but I am not sure why it's been so wet.
    Has anyone else used this flour? It has bigger particles in it than the KA whole wheat I've been using. Could this affect its ability to absorb moisture? And if it does, is it ok just to add flour until it feels ok? I'd say I added several handfuls to the mixer to get it to the slightly stick stage. Any less than that and I'd have had something more like soup than bread!
    I use a scale to measure all my ingredients, so they should all be accurate.
    By the way, what kind of scales are you all using? Mine is digital, but I wish it had smaller increments. It only goes by 5g and 1/4 oz. I keep having recipes which call for odd things like 52g. I can't do that! Of course, that 2g seems like about a teaspoon of flour, so maybe it doesn't matter mostly...
    Elizabeth
  • Les
    • Sep 2005
    • 2945
    Re: strange texture
    Elizabeth - I bought my scale at Bed Bath and Beyond. I has an auto zero, grams and oz's. It was pretty reasonable in price.
    Les...
    • james
      Brick Oven Merchant
      • Mar 2005
      • 4648
      Re: strange texture
      This is new to me. I can't quite imagine your whole wheat flour feeling wet or damp. I've only used a couple of different brands of whole wheat, but I haven't experienced that feeling. Also, across the different mills, the way the flour reacts to a fixed recipe doesn't change that much. Let us know how it comes out. I'm wondering if it will be heavier, and you brought the hydration down to get it to form a dough ball.
      Hmmmm.
      I like the scale we sell in the FB Store. It works with single grams, which is how I use it. Mine is holding up really well and I use it every day.
      • Jed
        • Apr 2008
        • 428
        Re: strange texture
        Elizabeth,
        One of the articles I read recently about flours used the amount of water a flour would absorb as an indicator of protein content. The more water a flour would absorb, the higher the protein.
        The chart in the article says that a bread flour with a 14 grams of protein per cup will use 2 cups and 1 tablespoon to absorb 1 cup of water, where a cake flour with 8 grams of protein per cup will use more flour to create the same consistency - 2 and 3/4 cups of the flour. The higher protein flour will absorb more water.
        If the flour you are experimenting with has a markedly lower protein than you have been using, then it would take less water or more flour to get to the correct consistency.
        I wonder if this is what you ran into with your new flour?
        I have been using the scale from Forno Bravo, and really like the results...
        JED
        • james
          Brick Oven Merchant
          • Mar 2005
          • 4648
          Re: strange texture
          Jed, that makes a lot of sense. I have always thought that whole wheat flour would be bread flour, with gluten in the 12%+ range, but maybe that's not true. A light weight flour would definitely not take on water the same way your bread flour does.
          • Frances
            • Aug 2007
            • 2186
            Re: strange texture
            How did the bread turn out Elizabeth? I get that sometimes, needing quite a lot more or less water, but with the self same flour I always use. I've always put it down to humidity, or just-one-of-those-things.
            Here are the scales I use and I really love them! Exact to 5 g with the weights I've got, but you can really see how much over you are and guess at the 2 g more. And like you said, does a teaspoon either way really matter anyway?
            http://www.fornobravo.com/forum/f18/...ales-4016.html
            • egalecki
              • Mar 2008
              • 1049
              Re: strange texture
              The bread came out ok. A little heavier than normal, but not as dense as I was afraid it would. It rose really well in the pans, which I use to make my huband happy. He likes tidy sandwiches.
              I am not sure what the protein percentage is- the bag lists 3g per 30, while the KA white whole wheat lists 4 per 30. I'm out of the regular KA whole wheat so I can't look at that one. I suspect that protein content may be it.
              I find that the KA whole wheat is ground much more finely than the Hodgson's. You know in BBA where he talks about sifting the whole wheat flour to get an approximation of high-extraction flour? Well, this is the one you'd use for that. You'd get a whole lot of bran particles from this flour.
              No complaints about the flour (if they're looking!) Just didn't behave the way I was expecting. It has good flavor and the end result was fine.
              I will look at the FB scale. I didn't realize you had one!
              I also made a double batch of rye yesterday. I nearly got eaten by it! I neglected to do the math- a double batch weighs a little over 12 pounds.. So now I have successfully baked approximately 20 pounds of bread in one firing. Anyone want a loaf of rye?
              Elizabeth
              • james
                Brick Oven Merchant
                • Mar 2005
                • 4648
                Re: strange texture
                That reminds me. I have to keep making both boules and pan sourdough bread. The kids ask for a "normal" sandwich from time to time.
                Elizabeth, glad to hear the bread came out OK in the end. I find it difficult estimating how much to bake. You feel badly throwing out stale bread -- but it's worse running out.
                Off to my mixer.
                • egalecki
                  • Mar 2008
                  • 1049
                  Re: strange texture
                  oh, there will be no throwing out. I freeze it. It works just fine that way. I also give it away to my friends. I haven't bought bread in months- I even make English muffins for my husband, who eats one every single day. They freeze ok too.
                  The sight of the enormous vat of bread rising was enough to scare me a bit, though! Bigger than a basketball punched down. Needless to say I had to mix it by hand. It's a very forgiving recipe, though.
                  Elizabeth
                  • texassourdough
                    • Nov 2006
                    • 1719
                    Re: strange texture
                    Hi Elizabeth!
                    You don't say which specific Hodgson Mill WW flour you used - though that missing fact doesn't do much good because Hodgson Mills doesn't provide protein specs on their flours. And the numbers they do report are wierd, such as ZERO % protein in their Whole Wheat Pastry Flour. The only flour of theirs for which I found a protein level was their Best for Bread at about 13%. I feel pretty confident their WW is somewhat lower - probably in the 10% range (more of a WW AP) which would be consistent with 3 grams of protein in 30.
                    As a comparison, KA white WW is 13.2% and Traditional WW is 14% so I think Jed was right on. And his "table results" seem to fit with the appx amount of extra flour you used.
                    Wish I could trade some bread with you. I need some rye right now!
                    Good Luck!
                    Jay
                    • egalecki
                      • Mar 2008
                      • 1049
                      Re: strange texture
                      The bag says whole wheat graham flour. It's a pretty coarse grind, which I like. I think, though, for most bread I'll stick with the KA whole wheat. The hydration is more consistent.
                      I can't get anything from Hodgson's Mill but whole wheat and rye- the selections for whole wheat have decreased, I've noticed, and their rye is the ONLY rye I can get. There are 12 million white flours, but only a couple of the others! This doesn't make sense to me in a world where more people are trying to eat more whole grains...
                      Elizabeth
                      • Jed
                        • Apr 2008
                        • 428
                        Re: strange texture
                        Elizabeth,
                        Here in the Northwest we have the benefit of this guy - Bob. Bob's Red Mill brand of grain products.
                        Bob's Red Mill
                        His business has grown to the point that his product line is pretty commonly available, including 50# sacks of the Whole Wheat and Dark Rye that we use (helps get the cost per pound down...), and several different options of just about everything (organic or not, fine grind or course, etc.).... It is a bit of an education working through his product catalog. Not just an education in marketing, but also just how many different kinds of "what - every" are available. I think his world (product wise) is similar to King Aurthur, but his roots are left coast not right coast. He also does a bunch of gluten free stuff, along with beans and such.
                        I'm sure mail order is an option, but probably cost prohibitive.
                        JED
                        • egalecki
                          • Mar 2008
                          • 1049
                          Re: strange texture
                          Actually, upon looking in the "organic" foods section, there are lots of Bob's products on the shelves. How do you like the WW flour? It's a little more expensive, but I'd consider it if it's good.
                          No rye, though. Just white and WW. Maybe if I ask...
                          Elizabeth
                          • Jed
                            • Apr 2008
                            • 428
                            Re: strange texture
                            Hi Elizabeth,
                            I have been plenty happy with the Bob's. It has been supporting my happy little farm of bacteria and yeast (eg. starter) for nearly a year now, and we eat the breads, biscuits, waffels, and etc. regularly to decent reviews...
                            I don't have any recent experience with other products (although we did buy a 5# bag of Bob's whole wheat pastry flour for a cake... liked the cake also..) so can't really comment on how this product line compares with others.
                            JED
