I suck
  • mfiore
    • Oct 2007
    • 919
    I suck
    OK. I have to make a confession. I've been telling my friends, neighbors, coworkers, even strangers about how cool my oven is (even though it's not done). I extol the virtues of wood fired cooking, retained heat, etc.
    The truth is, I'm not very good at using it. Actually, nothing has really turned out well yet. (except the pizza, that rocks!)
    I've overcooked ribs, undercooked chicken, and destroyed beautiful loaves of bread, all at the expense of my family, who eats it and showers me with lies.
    Here is my ciabatta from today. This is using a poolish starter, bread I've made dozens of times in the oven on a stone. Multiple problems. Just one of those days. The oven was taking forever to get up to a good temp. I have plenty of firewood, but it's still not properly cured. As a result, the bread over-proofed. I baked at about 450 degrees, not as hot as suggested. Steamed the heck out of the oven. 12 minutes with the door sealed. This is my result...
    Aside from a burnt crust, the top had a gummy charred covering. I think perhaps the oven wasn't hot enough for a steam "burst", and some spray may have settled down on the loaves.
    I share these moments to remind newbies that there is a learning curve to this. The forum is filled with amazing photos of food that we would be lucky to have grace any of our tables. I'll eventually get there, I hope my family can stomach the journey!
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
  • Les
    • Sep 2005
    • 2945
    Re: I suck
    Usually I try and give people words of encouragement and tell them its not all that bad. But this my friend... looks pretty bad
    I agree with you in regard to learning how to cook with these things, it is tough. I've been tempted to glue an oven range knob on the damn thing just to give me the illusion that I have some control.
    Les...
    • RTflorida
      • Jan 2007
      • 1446
      Re: I suck
      Yet another reason why I have not ventured into baking (one miserable attempt for me)
      Getting my pizza dough right every time is still a chore.......breads just scare the hell out of me.
      Don't be a pansy like me (still go to a local bakery when I want good bread), keep at it you will get better. Its good to take notes for future bakes, so that you don't accidentally revisit your past mistakes. Thats what I did with my pizza dough for a few weeks. I "thought" I was doing each batch the same...after going back and reading I always found something (seemed minor at the time) that I had done slightly differently. Eliminate those minor changes and I have great dough.
      On the bright side, maybe use the blackened ciabatta for a blackened grouper or redfish sandwhich.....or maybe the local ball players need a rub of charcoal under their eyes.
      RT
      • Frances
        • Aug 2007
        • 2186
        Re: I suck
        Hey, don't worry!
        I had my fair share of failures with the oven - still do come to think of it... remember that burnt bread? Just keep at it and I'm sure we'll all be drooling over your food photos in no time.
        One word of practical advice: Keep it small to begin with. Two drum sticks instead of the whole chicken, reheating leftovers (and I'm speaking from personal experience here), or make something with baking powder instead of yeast.... it'll all help you get a feel for the oven but won't hurt so much if it goes wrong.
        • texassourdough
          • Nov 2006
          • 1719
          Re: I suck
          Hi Mike!
          While I have been reasonably successful with WFO bread and never charred like yours, I think learning to make great bread in a WFO has some steep learning curve and timing the proof to the oven temp is one of the real challenges.
          How did you measure the temp of the oven for the bread? How large are the loaves? Was there more? I find it takes about 15 pounds of dough for me to load my oven adequately to get a great crust. Anything less is inferior. And...all that wet dough really depresses the oven temp (one experiment said to about 350) which then rises gradually back to the baking temperature range and finishes at about 435-450. (I start at about 475 based on a IR gun thermometer). It really looks to me like the oven was way too hot - either the temperature was wrong OR the load of dough was too small (so the temp didn't drop down much so the oven was too hot).
          In my experience the safest oven dishes are pot roasts of beef, pork, chicken (okay it's coq au vin but...) because they are wet and can cook all day at 250-350 (slight exaggeration) and have a lid to keep them from burning. Things cooked "naked" are much more vulnerable to problems - you can't just walk away and forget them or they will tend to dry out and/or burn (if the oven is over 275 or so). I think it is a lot easier to cook in the oven at 350 than at higher temps. Use of a thermometer to check the internal temp of the meat is a good idea.
          Hang in there!
          Jay
          • egalecki
            • Mar 2008
            • 1049
            Re: I suck
            Things will pick up when your wood is dried out better, too. It's really hard to get your oven ready at the right time to bake when the wood is not ready to go. How long are you firing the oven and to what temperature before you try to bake? Spread your coals? How long do you let it equalize? (takes longer than you'd think) I've burned the bottoms of loaves more times than I care to admit... but you can cut that part off. I know you want to serve perfect food that doesn't need bits cut off, but hell, I burn stuff in the regular oven sometimes!
            I'm getting to where if I'm only doing one recipe's worth of bread, I do it in the kitchen oven. Not because of the crust, like Jay, but because I'm lazy. And sometimes, like yesterday, I didn't check the timing properly and ended up with seven loaves of bread of different types all proofing at different rates and needing to go in the oven at different times! So, I ran the kitchen oven all evening. I still have two loaves retarding in the fridge, as an experiment. They'll go in the regular oven this afternoon.
            My first non-pizza food was beer-can chicken. It was great. You do have to keep looking at it and rotating it, though. I do a lot of beans and pot roasts. Um, one tip is if you burn the food a little on the bottom of the pot, you can salvage it if you don't stir all the burned muck up and just dump it into a serving dish. Don't ask how I know this...
            Elizabeth
            • texassourdough
              • Nov 2006
              • 1719
              Re: I suck
              Good comments, Elizabeth! And I won't ask how you learned not to stir - obviously it was from watching SOMEONE ELSE make that mistake and you want to protect them from embarassment! Must have been your mother-in-law!
              You are great!
              Jay
              • acbova
                • Jan 2009
                • 63
                Re: I suck
                This weekend I pitched a batch of pizza dough. I had not examined the flour closely and it had some bugs. But heck it's flour, water, salt and yeast! All pretty cheap! The biggest investment is time, but you need to travel that road anyway.
                Don't feed your family bad food! Let it go!
                • mfiore
                  • Oct 2007
                  • 919
                  Re: I suck
                  Jay,
                  Only three loaves in the oven. What do you do with 15 lbs of bread?
                  My temp stated 450 by IR . This was floor and dome. Walls a little less. Maybe they were in too long?
                  For what ever it's worth, we just tore the loaves in half and ripped out the inside. That bread was awesome!
                  Thanks for the encouragement/advice. I'lll keep you posted.
                  Mike - Saginaw, MI
                  Picasa Web Album
                  • texassourdough
                    • Nov 2006
                    • 1719
                    Re: I suck
                    Hi Mike!
                    We will assume your IR thermometer is correct (which is, of course, not certain, but... is probably within reason).
                    Your bread looks like it went in a 500 or 550 oven. I can't burn bread that bad in a 460 interior oven with a big stone (also checked as being 450-460 with IR) baked for 45 minutes. And you did it in 12!!!! Crazy!
                    Spraying the oven also cools it down so....more crazy....
                    Ahhhh.... Did you have the door open while it was cooling down to 450 or was it sealed? If it was open, the surface may have been at 450 and the interior at 500+ which could be how it got hot enough to burn the bread. The other trick is that it was 3 fairly small loaves so they couldn't cool the oven much. If the door was closed and the oven at equilibrium I don't understand how it could have been....
                    Wait...you said it was overproofed. Bread will often burn a little where the bubbles are right against the surface (a standard ciabatta issue). Also...it tends to burn where it is dry - did the bread form a skin while you waited for the oven to get to the right temp?
                    RE: 15 pounds. That is exactly why I don't usually use my WFO to make bread. It is too much work and I am absolutely fixated on how I want my bread to look and I can't get that look in a partially loaded oven. So I pretty much do a ton or none. I am sneaky though. When I do bread in the WFO I always make ciabatta as one of the breasds so I will have REALLY WET DOUGH to help humidify the oven!
                    Look forward to your reply regarding the door....it is the only thing I can think of that really makes sense! (As an aside, when making bread I burn for about 1 1/2 to 2 hours and sweep the oven, close it up and let it heat soak to about 460. Mop it, load it, spray it with water, and bake for about 20 minutes. Then open and rearrange the bread. Close and finish baking, about 25 more minutes for 1 1/2 # boules.)
                    Good Luck!
                    Jay
                    • mfiore
                      • Oct 2007
                      • 919
                      Re: I suck
                      Wow. Lot's of things I never considered. Much more than just throwing loaves into an oven!
                      Yes, the door was open during much of the cool down. I also did not likely give it adequate time to equilibrate.
                      Also correct on both accounts, the loaves had big, big bubbles that formed under the skin (again, it over-proofed as I waited and waited for the oven to come to temp). the surface was a little dry.
                      I did not mop down the floor, just brushed it really well. Also, I steamed it by using a garden style sprayer, creating a mist in the oven. As others have suggested, I filled the oven with steam, loaded the loaves, then again steamed the oven before sealing the door. Is it possible the "mist" fell on the loaves, making them wet. There was some loose flour on the tops. This may have created that gummy coating.
                      Mike - Saginaw, MI
                      Picasa Web Album
                      • texassourdough
                        • Nov 2006
                        • 1719
                        Re: I suck
                        Bingo!
                        The oven was undoubtedly way hotter than 450 then! And with minimal dough to cool it the temp shot up fast when you closed the door and...
                        Every oven has a different personality and you have to learn your oven... IMO baking bread is the most precise/complex thing to do in an oven. There are two different clocks ticking that may or may not be coordinated (the rising of the bread and the firing/cooling of the oven). I have a lot of respect for the professionals who do it routinely (which probably makes it easier for they have a "routine". Doing it occasionally is HARD and really easy to screw up!) Kudos to CanuckJim and DutchOven!
                        Glad to help!
                        Jay
                        • egalecki
                          • Mar 2008
                          • 1049
                          Re: I suck
                          I will let the oven cool off with the door off, but I always, always put my door on when it's getting close and let it sit for 1/2 hour to get it equalized inside. This, combined with spreading my coals around for the last 20 minutes or so of my heat-up, really makes it so I don't get weird burned spots in some places and not in others.
                          It takes thinking about the oven as not just a hot surface, but as a heat-storage organism. For those who just fire up until it gets to 500 inside, they miss the part where it soaks up the heat and their food is undercooked. For those who fire it up all the way but don't let it sit with the door on so all the heat evens out amongst the bricks, they get burned spots. Let's just say I've been in the second camp, with the pictures of bread with brick-shaped burn marks to prove it...
                          If you're cooking with the fire still in the oven, that's different, but you don't usually do bread that way. I have done chicken, roast beef, and the like that way, though. It was GOOD. You just can't walk away from it- it needs nearly constant attention. The results, however, are worth it. I got Mary Karlin's Wood Fired Cooking book a week or so ago and it has all kinds of things in it I can't wait to try.
                          First I have to refab my door. Dang thing crumbled again.
                          Elizabeth
                          • DrakeRemoray
                            • Mar 2006
                            • 1215
                            Re: I suck
                            I have sure burned plenty of loaves. I think one of the best things to do is to concentrate on sourdough bread that have been retarded in the fridge. They can stay in the fridge until the oven decides to cooperate and cool down enough for baking.
                            This saturday I had a noon pizza party (20 pizzas) and was sitting out by the oven at midnight waiting for the dang thing to cool down enough to bake. But I really really did not want to burn my bread!
                            So my advice is to try some sourdough or other retarded breads. It really helps on the timing.
                            Drake
                            My Oven Thread:
