I have a question for the hearth bread bakers out there.
When placing a boule, or baguette directly on the hearth, the bread picks up a fairly strong hearth aroma. I heat soak the bricks well and make sure all the soot is burned off. I spread coals and wait. I rake coals out and mop floor and wait. I spray water before placing the loaves. I spray again when placing loaves into the oven ans seal door. I crack door later in the baking time and remove loaves and place on cooling racks.
When the loaves are taken out of the oven, they do not have an overly pronounced hearth smell, but after cooling, the hearth smell is very strong.
Items placed on sheets and baked in pans turn out spectacular.
The pizza is different, though. Baked on the hearth, it doesn't pick up as much hearth aroma, probably because it's only there for a short time.
Is this typical? Or, am I getting too much hearth aroma because the hearth is still too new? Do most use pans?
Thanks for any info,
Timo
Timo
I am thinking the perlcrete insulating layer probably has more water hiding in it and the heat draws the moisture toward the hearth. Just have to keep firing away until she's nice and dry I guess.
