Sorry but this is going to be a long post:
I've been testing the Parisian baguette recipe from the FB Bread cookbook in my WFO over the holidays. While the instructions are pretty clear, I think I am hitting some problems that are related to the weather. To set the context right, December is a cool time of the year for us with room temperature at about 80F and humidity at about 55%. My kitchen is a bit warmer at 85F.
When I start working the dough in the mixer, the internal temp gets to about 87F after running at speed 2 on a Kitchen Aid for about 4 mins. The dough is still quite sticky so I work it by hand for a few more minutes, adding flour as I go along to get it to the tacky stage.
Even though I work the dough thoroughly ( including slamming as recommended on the video) the dough won't pass a window pane test, it will rip. But after all the kneading I worry that I might over work the dough.
The resulting bread looks ok with a light brown color, although I would prefer a thicker crust. Internal texture is on the chewy side, with mostly small holes and a few medium sized ones. Oven temp is about 500 and I steam 10 minutes prior and just before I put in the bread.
Key concerns for me are:
1. Is passing the window pane a critical test? Do I keep kneading until I get it?
2. With the room temperature at 85F, my dough will always exceed the recommended internal temp max of 81F. How do I deal with this?
3. (Not directly related to weather) I suspect the gluten content of the bread flour I can source is not great (I have no way of getting the actual content). Is adding vital gluten an option? If so how do I figure out how much? And how will it affect the overall bread texture?
Many thanks in advance!
