Door for bread baking???
  • heliman
    • Sep 2009
    • 1181
    I make a quick loaf of bread yesterday in the WFO. I got the fire to around 240 degrees (measure with IR gun) and then placed the loaf in to bake, without the door. After about 10 minutes I noticed that the loaf wasn't browning so I put the door on and then it seemed to cook normally.
    Quick question to the experts ... is it necessary to use the door when baking bread in a WFO? I thought that is was optional but after my last baking exercise I think that this could be wrong. Maybe a higher temp would make a difference.
    TIA
    / Rossco
  • kebwi
    • Aug 2009
    • 1090
    Re: Door for bread baking???
    Not being remotely qualified to respond, here's my take on it.
    If I understand things correctly, the air in an open-door oven is a mess. It's swirling around, moving all over the place, heat (and temperature) are constantly moving, shifting, wafting, etc. For foods that mostly cook through contact with the floor (like pizza), this doesn't matter (am I wrong about how a pizza cooks? Correct me please!). For foods that rely heavily on absorbing heat from the air, however, this won't work. You need to create a "smooth" environment. Closing the door permits the heat to even out throughout the interior and for things to generally calm down. Heat is then efficiently absorbed by all surface (and solids) in the oven, namely food that is baking.
    That's how I think it works. Of course, my theory must be slightly flawed since it suggests that pizza is effectively grilled on a hot flat griddle-like-surface, which can't be correct because that isn't the traditional way of cooking pizza, so I must be a little wrong about something here.
    I'm sure someone else will chime in...
    • heliman
      • Sep 2009
      • 1181
      Thanks for that overview Keith ...
      I am just wondering then how ones controls the internal temp with the door fitted as I would think that the fire continues burning and continues to heat up the oven chamber. I would also think that the oven would reach a point when all the oxygen is used up and the fire starts to die down. Perhaps leaving the door slightly open would allow the heat to be regulated, and the oven maintained at the desired temperature. This looks like a pretty exact science!!!
      / Rossco
      • kebwi
        • Aug 2009
        • 1090
        First of all, I just started reading the FB pizza book in prep for getting my oven through the curing process and it explains some of my earlier confusion. Pizza in a brick oven cooks in three ways: direct contact with the hot floor, radiation from the ceiling, and the draw and flow of air via the open door and heat-induced motion.
        Second, although I am speculating, I seriously doubt an oven will continue to heat up after you put the door on. You admit that the fire will suffocate but question whether it will first heat up for a while. I strongly suspect that in a small oven a fire of any reasonable size will suffocate in a matter of seconds, a minute at most. Once the oxygen is depleted (it isn't "gone" of course, that's the wrong terminology) the oven immediately enters the cool-down phase (which can obviously take several days to complete). The point is, mathematically, an oven starts cooling down within seconds of putting the door on. It certainly doesn't heat up since there is no source of additional heat. Cooling down is the only option left.
        That said, I can imagine that some areas in an oven may heat up when you put the door on. The reason is that when you close the oven, it starts equalizing. An open oven is pulling in fresh air and evacuating old air, it's a stirred up heterogeneous mess. A closed oven mixes up until all of the air and the interior surfaces are homogeneous...so toward that end, some of the colder areas might heat up while some of the hotter areas cool down...then the whole thing starts slowly cooling down.
        As for whether one should or could crack the door to keep a fire going for the purpose of regulating the temperature, that is well beyond the realm of my knowledge, or even speculation, but I'm not aware of other FBers doing that, so I suspect it isn't the "right" way to do it. I think the right way to do it is to reach your target temperature (or perhaps barely surpass it), put an insulated door with a good seal on, and assume the oven will have the proper temperature for the requisite time to cook certain kinds of foods...but I really don't know what I'm talking about!
        • Pdiff
          • Oct 2008
          • 119
          Hi Rossco,
          I think most of us cook breads without an active fire, that is, the fire is built, gets to maximum heat and is allowed to burn out, The fire is then removed, the floor cleaned, and the bread is baked. I've always done the later step with door on.
          That said, pizzas and flat breads are cooked with fire to the side and door open (see link for a short youtube I made for interested family and friends (Pita & Pizza)). Even after this shot, though, I cleaned out the oven and baked some bread. The art and science are trying to match up the timings for the dough rise and oven temps. I've got that down pretty well now, but with warmer weather coming, I'm sure I'll have a few misfires (pun intended :-) before I hit it right again.
          Pdiff
          • egalecki
            • Mar 2008
            • 1049
            There are a number of threads in which proper bread technique has been addressed- I don't know which ones they are right now, unfortunately. See if you can find them- you'll find they have a lot of information on baking bread in general.
            I always use my door to bake. You do have to heat the oven fully or it isn't heated all the way through. Think of it this way- if you just heat the surface to your desired temp, as soon as you stop heating, the bricks suck the heat further in, leaving your oven floor cooler. Your door helped stop heat leaving through the front door, but I doubt that it ever got hot enough to start with.
            To sum up:
            -build a fire and "go white", I allow it to stay that hot about 1/2 hour so the heat saturates the oven.
            -Once the oven's saturated and the fire's down, I scoop out the coals and ash and put the door on for 1/2 hour so the heat is evenly distributed throughout the oven. This is very important.
            - after that 1/2 hour or so, I take the door off, sweep off the floor and if the oven's still too hot, I leave it off for a little while- then I put the door back on while I get the bread ready to go in.
            -when the oven's at 600 to 550 F, I swab the oven floor to get the ash up, bring out the bread, check the temp (should be between 500 and 550 for most of my breads) and spray the oven with water until the steam rolls out the door- load the bread, spray again, and put the door on.
            -I check the bread after 5 to 10 minutes, move the loaves around if I need to (even letting the oven equalize, sometimes I have one wall area hotter then the other or if I am doing a lot of bread, I will need to move an interior loaf to the outside and vice versa. Just do it quickly) If the bread isn't ready (and it can be, depending on how big the loaf is and its shape) put the door on and wait another 5 to 10 minutes. Nearly all my loaves will be finished, even the big ones, after 20 minutes at 500.
            I can sometimes do multiple batches, but the second batch works better if it's a dough that doesn't need to go to 205 or better- a 195 degree enriched loaf does fine. Usually I'm doing 10 to 12 pounds of dough at a time on that first bake, so I don't need a second batch.
            I give a lot away, just so you know. I don't eat it all! I just really like several types and so I like to have a couple of different loaves around at a time... and I'm still working on cooking in smaller pots from raising 8 kids- a meal for two looks impossibly small, even after several years...
            Elizabeth
            • heliman
              • Sep 2009
              • 1181
              Great summary - thank you Elizabeth. I was defnitely doing it completely wrong!
              Hope to give it a go using the proper methodology this (long) weekend...
              / Rossco
              • MK1
                • 123
                Not that it's a requirement, but I credit TexasSD with advising that the oven moisture is ideal with 15lbs or more. My experience confirms that, so get that 20qt mixer in gear!
                Mark
                • heliman
                  • Sep 2009
                  • 1181
                  Can you elaborate on that statement please Mark ... do you man that one needs to bake 15 lbs of bread at one time to get the best baking results??
                  (Tks for the vid Pdiff - good to see the process from start to finish!)
                  / Rossco
                  • MK1
                    • 123
                    Rossco,
                    In a baking thread a few months ago Texasourdough, (he has an Alan Scott barrel vault) posted that his loaves produced the best spring, crust and crumb when he loaded to the 15lbs level. Most of the spring in the bread is provided by the water in the dough cooking out. The water can't get out after the crust starts to set, so the quicker the moisture leaves and the longer the time in which it can still leave helps the springing of the loaves. The moisture content, ( more steam to a point delays the crust set) and the temp have a lot to do with spring. I find with my oven anything over 10 is pretty good.
                    Mark
                    • heliman
                      • Sep 2009
                      • 1181
                      Thanks Mark ...
                      I tend to only make 1 -2 loaves in a session. Looks like I may need to brace the neighbours for the impending "Big Bread Giveaway" when I crank the numbers up a bit.
                      I often given them "surplus" pizza so I'm sure that they won't be too surprised at the latest bargain coming their way.
                      / Rossco
                      • egalecki
                        • Mar 2008
                        • 1049
                        You don't have to bake more bread than you want to to get good crust. You can get a garden sprayer and use that- it really does work just fine. Texassourdough is right about bigger loads not needing spraying, but a smaller one is just fine with spraying.
                        Especially if you're just getting started with bread in the wfo, or bread in general, smaller loads are better-- trust me, until you are used to what your recipes need and how your oven performs, you're going to burn some bread. I charred the crap out of a bunch of loaves- my friends generously referred to them as "well-caramelized". I cut the bottoms off and ate it anyway, but 3 loaves burned are better than 10...
                        Mostly my troubles were related to insufficient patience. I wasn't closing the oven up and letting it even out. If the floor is HOT and the dome isn't as hot, you'll burn it every time. Give it the time it needs to even out.
                        It takes practice to not over proof your dough while you wait, but once you figure it out, it's not so bad. And slightly under-proofed dough is pretty ok- you'll get a denser crumb and amazing crust rip...
                        Elizabeth
                        • GianniFocaccia
                          • Jun 2009
                          • 1645
                          The following may help to clarify the properties of bread as it proceeds through the process of baking. This is directly from Harold McGee's book ON FOOD AND COOKING -The Science and Lore of the Kitchen, pub. Scribner, 1984.
                          Ovens, Baking Temperatures, and Steam
                          "Steam does several useful things during the first few minutes of baking. It greatly increases the rate of heat transfer from oven to dough. Without steam the dough surface reaches 195F/90C in 4 minutes; with steam, in 1 minute. Steam thus causes a rapid expansion of the gas cells. As the steam condenses onto the dough surface, it forms a film of water that temporarily prevents the loaf surface from drying out into a crust, thus keeping it flexible and elastic so that it doesn't hinder the initial rapid expansion of the loaf, the "oven spring." The overall result is a larger, lighter loaf. In addition, the hot water film gelates starch at the loaf surface into a thin transparent coating that later dries into an attractively glossy crust."
                          "Professional bakers often inject steam under low pressure into the oven for the first several minutes of baking. In home ovens, spraying water or throwing ice cubes into the hot chamber can produce enough steam to improve the oven spring and crust gloss."
                          "When the bread first enters the oven, heat moves into the bottom of the dough from the oven floor or pan, and into the top from the oven ceiling and the hot air. If steam is present, it provides an initial blast of heat by condensing onto the cold dough surface. Heat then moves from the surface of the dough by two means: slow conduction through the viscous gluten-starch matrix, and much more rapid steam movement through the network of gas bubbles. The better leavened the dough, the faster steam can move through it, so the faster the loaf cooks."
                          "As the dough heats up it becomes more fluid, it's gas cells expand, and the dough rises. The main cause of this oven spring is the vaporization of alcohol and water into gases that fill the gas cells, and that expand the dough by as much as half it's initial volume. Oven spring is usually over after 6-8 minutes of baking."
                          Comparing the gas oven to the (superior for baking if not in convenience) wood-fired oven, McGee says "because they (gas ovens) are vented to allow the escape of combustion gases (carbon dioxide and water), gas ovens don't retain the loaves' steam well during the important early stage."
                          So, to optimize the wonderful bread-baking capability of a WFO, it might be a good idea to keep the door on, at least during the first 6-8 minutes of the bake. Additionally, if we bake fewer than the 10-15lbs of dough that inherently renders the minimum steam for optimum heat transfer, it appears a few sprays (or ice cubes etc) of water would help the bake along nicely.
                          John
                            I usually place a small pie tin , filled with water into the oven, prior to placing the bread. Seems to work and all the water has gone by the time the bread is cooked. I also usually have the bread on baking trays. This prevents burnt bottoms and makes the handling easier
                            • Dino_Pizza
                              • Feb 2008
                              • 1036
                              The water tray is great idea Dave. Especially for the bigger ovens with 2-3 loaves only. It would need the moisture.
                              Rossco, I took Elizabeth's great advice and last 2 times, my breads were terrific. It only took 1 minute to use my fireplace shovel and clean out the coals, then I wet mopped and shut the door for 20 minutes. The IR said it was still too hot so I mopped again and got my temps almost there, but still hotter since I use a sprayer. Then I loaded the oven, put the door on, tilted the door back, spray thru the small opening and shut it.
                              Let us know what you do next and how it comes out!
                              -Dino
                              My Oven Costs Spreadsheet
                              My Oven Thread
