Hi all. After a pizza fest this Friday, I want to fire up my oven on Saturday and push a couple of cast iron grill plates into it, Plan is to leave them there for about half an hour or so to get piping hot, drag them out with a rake and drop some seasoned sirloin steaks on them.
I need to season the cast iron grills though, and after a google search I found a list of oils which give temperature ranges. Problem is, they only go up to about 280c, and my oven gets to well over 500c.
So, is it even worth trying to season the cast iron grill plates or will the oil just burn off at those temperatures just leaving the bare cast iron? I intend to brush the steaks with butter and then drop them on the griill plates, so question is, should I season the grill plates and if so, what is the best high temp fat or oil out there?
Thanks!
Thanks!
