Salmon sticking to stainless steel pan
  • Salmon sticking to stainless steel pan
    Does anyone know how to keep Salmon from sticking to a stainless steel pan (Allclad'ish)? I use stainless in the brick oven to avoid non-stick pans, but my Salmon sticks when I roast it flesh side down.
    Any ideas?
    Pizza Ovens
    Outdoor Fireplaces
    Stickiness
    James,
    Just a thought, but you might try searing it very quickly over high heat in olive oil, both sides, before you put the pan in the oven.
    Jim
      sticking salmon
      For baking and barbeque, i cut a small piece of foil to fit the skin side of the fillet. Bake or grill skin side down, and then turn it over and peel off both the foil and the skin which sticks to it. The top side doesn't stick once it's slightly cooked.
