24 hour black-eyed peas
  • 24 hour black-eyed peas
    I hate to waste all that heat, so I filled the crockpot with dried black-eye peas, tomatos, sausage, onions, cilantro and jalapenos and spices.
    I put it in at 520 degrees, so I will have to check the water in a couple hours then again in the morning. I plan on putting the lid on before bed tonight and eating them tomorrow about this time. I sure hope the crock pot doesn't crack....
    Re: 24 hour black-eyed peas
    Almost bedtime, so I added another 3 cups of water (I added three cups around 8:00), stirred them and doored it back up. The temp is down to 410 degrees.
      Tscarborough,
      We will use the oven heat to cook off a pot of beans just about every other time we heat up the oven... again, I like to make use of the heat in that 'retained heat masonry oven'.
      I have collected a couple of cast iron pots, and that is what we use to slow cook stuff. I try to use the enameled pots with the recipe's with tomatoes... try to keep the acid from the tomatoes from cutting the 'cure' on the cast iron.
      I will typically get the temperatures closer to the 350 degree mark before putting the pot in the oven for an overnight cook. I'll be curious to see how your pot - o - beans comes out starting at the higher temps.
      Keep us posted!
      Thanks,
      JED
        How do you measure temps?
        I have quite a few "dutch ovens" they type scouts use most often and hope to use them in the future.
        Derk
          It was at 350 this morning at 6:00AM, I added 3 more cups of water and sealed it back up to cook for 11 more hours (when I get home from work).
          I use a IR heat gun from harbor freight.
          I have all sizes cast iron pots, dutch ovens, and frying pans, I didn't even think about using them for some reason.
            Thanks,
            I think I will keep my eye out for a gun. We have a Harbor Freight north and south of our place.
            Thermocouples are neat but a little too pricey, would much rather put the extra $ into the oven or pizza supplies.
              Oh yeah.
