Leftover dough
  • RandyJ
    Re: Leftover dough
    Gugahulk if you have a gas grill you can do it in there too. That is what I have been doing for the last 7 years or so. Hopefully I can do my first pizza in the oven next week. The grill can get you a little closer to pizza temps. Good luck
  • gugahulk
    Re: Leftover dough
    Originally posted by hodgey1 View Post
    When I said home oven I meant the one inside your house. A home oven with a stone shelf will bake a very good pizza when preheated for atleast an hour at 550*F.
    Ohh... nice ok I will give it a try.
  • hodgey1
    Re: Leftover dough
  • gugahulk
    Re: Leftover dough
    Highly recomend that you do it in your home oven on a stone and not on the grill. Not enough stored heat for the top of the pizza to get cooked properly using a grill.
    Thanks.. really appreciate it. My oven will not be ready until 2 months from now. Do you have any recipe I can use now? Just for fun, never worked with dough before and love to try one that is a proven method from someone I kind of know... I know there is a lots of recipes online but coming from someone in the forum is kind of a proven thing. Thanks for getting back to me...
  • hodgey1
    Re: Leftover dough
    This recipe below is from pizzamaking.com for a NY style crust from a noted dough expert Tom Lehmann. I've been making a version close to this for years with great success. Highly recomend that you do it in your home oven on a stone and not on the grill. Not enough stored heat for the top of the pizza to get cooked properly using a grill.
    Chris
    PERCENT INGREDIENT
    100% High gluten flour
    58 - 65% Water
    0.5 - 3% Salt
    1 - 2% Olive oil
    0.17 - 0.5% Instant dry yeast
    Note: Water temperature should be adjusted to give a finished dough at 80 to 85 ?F.
    This formula produces a somewhat thin crust with a tough, chewy texture.
    How to Prepare:
    Standard Dough Making Procedure: Put water into the mixing bowl, add the salt and sugar, then add the flour and the yeast. Mix at low speed for about 2 minutes, then mix at medium speed until all of the flour has been picked up into the dough. Now add the oil and mix in for 2 minutes at low speed, then mix the dough at medium speed until it develops a smooth, satiny appearance (generally about 8 to 10 minutes using a planetary mixer).
    The dough temperature should be between 80 and 85F. Immediately divide the dough into desired weight pieces and round into balls. Wipe the dough balls with salad oil, and place into plastic dough boxes. Make sure that the dough balls are spaced about 2 inches apart. Cross stack the uncovered dough boxes in the cooler for 2 hours as this will allow the dough balls to cool down thoroughly, and uniformly. The dough boxes can then be nested, with the top box being covered. This will prevent excessive drying of the dough balls.
    The dough balls will be ready to use after about 12 hours of refrigeration. They can be used after up to 72 hours of refrigeration with good results. To use the dough balls, remove a quantity from the cooler and allow them to warm at room temperature for approximately 2-3 hours. The dough can then be shaped into skins, or shaped into pans for proofing. Unused dough can remain at room temperature (covered to prevent drying) for up to 6 hours after removal from the cooler.
  • gugahulk
    Re: Leftover dough
    Hulk,
    I normaly place it directly on my preheated gas grill. The situation is when I have dough around two or three days later after useing my WFO.
    I'll look for some pictures.
    Chris
    Thanks Hodgey, I just realized my iphone did some out corrections on the spelling on my previous post and it was not understandable. I rewrote it. I was also asking for an easy pizza dough receipt. These damm iphone are great sometime and sometimes they are terrible.
  • hodgey1
    Re: Leftover dough
    Hulk,
    Chris
  • gugahulk
    Re: Leftover dough
    Can anyone give me an easy recipe for pizza dough so I can make it on my BBQ grill for now since my oven is not ready? Need to start practicing.
  • gugahulk
    Re: Leftover dough
    One of my families favorite things is, I take leftover pizza dough and strech it out by hand thicker than normal then place it directly on to my hot BBQ grill. Then I cook it on one side, turn it over once its set and brush it generously with olive oil, garlic,garlic salt, parm and serve wedges of it as a side with salad or dinner.
    You put it on the BBQ grill? Not the oven? I have my bbq ready but oven is going to take another month. So I would like to try this. can you send some pics? if you have any.
  • hodgey1
    Re: Leftover dough
    Originally posted by stonecutter View Post
    I do the same thing too, but with cracked black pepper. Sometimes I'll add a bit of dried basil as well.
    Sound good also! My oldest daughter says she like the BBQ bread as well as the pizza.
  • stonecutter
    Re: Leftover dough
  • hodgey1
    Re: Leftover dough
  • Tscarborough
    Re: Leftover dough
    Black olives and pepper and onions. Garlic olive oil and a little salt.
  • Tscarborough
    Re: Leftover dough
    Here is a rosemary bread:
  • Tscarborough
    Re: Leftover dough
    Dave, that is called foccacia bread. It is easy and the same dough that is used for pizza. I spread it out on a flat pan, cover it with plastic and let it rise. I usually cook foccacia on the day after when the oven is running 4-500 degrees F.
    My favorites are rosemary bread (lots of fresh rosemary and garlic infused olive oil) and black olive with onion. I am making some soon, I will post pics.
