Coffee Machines
  • PizzaPolice
    Re: Coffee Machines
    Wow! ...And I thought I was living the good life with my $15 Senseo.
    Damn Juan Valdez. He started this mess... #@%$& Mountain Grown!
  • sammy
    Re: Coffee Machines
    I posted a longer reply, but something must have happend because I don't see it out there.
    Yah, those beans sit in those bins for a long time also. If I were you, and I had to do one thing to improve the quality of my coffee at home, I would buy a grinder before investing in a new brewing method. If you have a little cone filter and you are pooring directly into that (i.e., not using a drip machine), your method should actually give you pretty good results if you have good beans.
    Tips...buy a cheap burr grinder (they shave the beans instead of chopping them - giving more surface area for brewing and generating less heat (which isn't the best thing for the beans/grounds)). If you can't afford a decent burr grinder, the best blade grinder I know of is actually fairly inexpensive - the Bodum C-Mill, but as with all blade grinders, it operates like a blender and will generate some heat, which isn't the best thing for the beans.
    In general, you want to grind your beans as fine as you can without them seaping through your filter and into your cup of joe. If your cone filter and grounds are at the right balance, the idea brew time (water in to water out) should be about 2 min. The best thing to do is...boil the water, take it off the burner for about 5 seconds (to allow it to drop closer to 190-200 deg F - the ideal brewing temp), then pour just enough water in to pre-saturate your grounds. After this, pour more water in to brew the rest of the cup of coffee.
    That is actually one of the better ways to brew coffee, and it is low maintenance and fast clean up.
    The next tip is to stop buying your coffee from the grocery store and find a local coffee shop that roasts their coffee on site :-) Let me know (ssiegel@amesic.com) if and when you get yourself a grinder and I will roast you something fresh to see what I am talking about :-) Actually, many local shops are hackers who misroast their beans just like the people who do it for the grocery stores. Anyway, let me know and I will send you something tasty to experiment with :-)
    Have fun
  • Ken524
    Re: Coffee Machines
    Originally posted by sammy View Post
    Do you buy beans or grounds? Do you own a grinder? Burr or blade?
    I'm pretty unsophisticated about coffee. I buy ground coffee in the coffee isle of the grocery store. Sometimes I'll buy a bag of beans and use those in-store grinders (the kids love to dump the beans in and see the grounds come out ). I have no idea if those grinders have burrs, blades (or heaven knows what else) in them - I probably don't want to know.
    Grounds stay freshest for about two days after ground.
    Oops.
    But I do store them in a cool dark place.
    In all seriousness, I am considering buying a small grinder to grind a few days worth of coffee at a time. I can justify that. And the Moka machines are so inexpensive, it would be fun to get one to play with.
    Thanks for the feedback!
  • sammy
    Re: Coffee Machines
    A moka machine will give you a different type of brew, but not necessarily a better cup of joe....and a Moka is not an espresso and neither are a traditional drip brew - they all go for something different. Do you buy beans or grounds? Do you own a grinder? Burr or blade?
    In general beans stay freshest for about two weeks after they are roasted. Grounds stay freshest for about two days after ground. Both should be kept in a dark, cool, dry location - and NOT the fridge or freezer where they will absorb other smells and flavors.
  • rlf5
    Re: Coffee Machines
    Ken
    The ceramic cooktop should be fine.
  • Ken524
    Re: Coffee Machines
    Wow... I just stumbled on this thread. As a 3rd shift worker, I've turned into a coffee junkie over the years.
    Here's my coffee dilemma: My daily routine includes spending about 5 minutes in the morning boiling water and pouring it through a #2 filter with Starbucks ground coffee into my coffee mug.
    The results are pretty lame. I have a 20 year-old 10 cup Mr. Coffee that we use for parties. The coffee is a little better but it's too much trouble for one or 2 cups.
    I looked at a few Espresso machines and had major sticker shock (DaveW can build an oven for less then one of those!)
    Am I understanding this right that I can buy a 3 Cup Bialetti Moka Express Stovetop machine for under $20USD and solve my problem of crummy morning coffee?? Will this thing work on our ceramic cooktop?
    Thanks!
  • sammy
    Re: Coffee Machines
    A blend is typically better for espresso because you are looking for a balance that is hard to get from one type of bean. Coffee....yummmmm
  • billrd
    Re: Coffee Machines-Unspeakable sin
    I think I might have committed an "unspeakable sin" in the coffee world and I must confess. I bought a "nespresso machine!"
    About 2 weeks ago I was expressing my newly found coffee knowledge,(thanks Michael), at dinner with friends. One friend mentioned he had been considering buying a DeLonghi Nespresso machine and proceeded to explain this system run by Nestle.
    I had never heard of this "nespresso" concept before so over the next few days I did a bit of research. I read a lot of reviews on line and found it hard to find any negative ones.
    For those like me who are not familiar with the system, it uses a coffee capsule which is only available from Nestle. Each capsule is meant for one cup of coffee (short or long). There are 12 varieties of coffee including 3 decaffienated. The price of each capsule in Australia is 64 cents.
    There are about 10 different machines in the range from manufacturers like Krups, DeLonghi, Magimix and Miele. The top end machines are automatic and have milk frothing wands and cup warming trays. All the machines work at 19 bar of pressure.
    The bottom line (confession) is I bought the entry level DeLonghi machine for about $200 (after a $50 cashback offer).
    So far I have only used a couple of the varieties of coffee but have been very impressed. The result is as good or better than any coffee I have had in coffee shops.
    The machine I bought takes up as much space on the kitchen bench as a toaster (much to the delight of the missus) and doesn't have a milk frothing wand but came with a clever electrical jug called an aeroccino which heats or froths milk for lattes and capuccinos.
    Overall I am very happy with my purchase. The system is simple, quick, takes up little space and makes a good cup of coffee.
    I guess the downside is that I am locked into the Nestle system for coffee.
    Cheers
    Bill
  • Xabia Jim
    Re: Coffee Machines
    Thanks Michael, I've finally learned what a Moka pot is and how it works. I've seen lots of them but never tried them.
    Coffee and FB are a tradition....I usually get up every morning before the queen, make a cup of coffee and hit the internet...invariably checking FB.
    I've been grinding my beans at home for years, most recently upgrading to the Kitchen Aid DC grinder. Effective and quieter. We buy beans from a local roaster but mix regular and decaf (Sumatra usually) so we get a lower caffeine blend. (my b-i-l has his own bean roaster at home..pretty neat)
    But I use the Mellita fiter cone arrangement into an Alfi pot. Boil water, grind beans, pour over grounds in filter cone and have hot coffee available all morning in the Alfi vacuum flask. Never boiled! Done it for years this way!
    Now in Spain, we go out for a solo, cortado or con leche regularly. and also use a french press sometimes. Different strokes!....but now I'll try a Moka. Thanks
    PS Yup, camp coffee at camp...throw in some egg shells to settle grounds)
    By the way, how do you store your beans to keep freshness? I put my blend in the freezer and only take out a few days worth at a time..
    Thanks for the coffee education....Jim
  • michael
    Guest replied
    Re: Coffee Machines
    Earl....sounds like great "camp" coffee! Your method is not miles away from the oldest of all coffee cuisines - Turkish. Low-tech and enjoyed by about 4 billion people around the world. Enjoy your lovely mellow brew!
    Damon,
    The tasting wheel used in a coffee or tea "cupping" room is identical to the one use in wine. All this interest in good coffee doesn't surprise me for one minute...you all are connected to your palates and good is good...bad is bad. Which reminds me of a quick story. One of my coffee customers in England is a chef named Michael Caine (no, not that one) who has a 3 Michelin star restaurant in Exeter. One day, after about three visits to train staff, I asked Michael was if there was anything in particular he wanted me to focus upon on this visit? He said, "I want everyone who comes in contact with either the espresso machine or the filter coffee maker to understand that coffee is food and people put it in their mouth...it's important that it taste good!". That simple concept became the sole focus of all subsequent training classes. Thank you Mr. Caine!
    Just a side note, I admired Michael C. for many things but one in particular stood out...not only was he the chef of a 3 Michelin star restaurant...but he did it with only one arm! True story!
    So JC, if your Saeco makes coffee that tastes good, is easy to use, AND includes a grinder with adjustable burrs...I'd say someone at the factory understands what it takes to make great coffee at home! Well done whoever you are!
    Michael
  • Bacterium
    Re: Coffee Machines
    James I heard that same rumour when I bought mine over a year ago......Gaggia is not as big here but still around.
    Most of the domestic stuff here tends to be Saeco, Delonghi, Sunbeam, Kamrook - all a very mixed bag. Then in your more specialised shops you tend to see the likes of Jura, La Cimbal, Lavazza, Krups, Gaggia, Rancilio...among others
    My Saeco is the Magic Deluxe (single boiler) model. I'm guessing overall not that much different to the Vienna as far as the base brew group etc. My mate has a Magic that is over 10years old and its been very reliable - which is what influenced me to a point.
    In Adelaide we have pretty crap drinking (mains) water. So whenn I did my kitchen renovation I put an R.O. (Reverse Osmosis) unit in and thats all I put in my machine now. Its surprising how other water - mains, filtered (depends) or bottled spring tends to mask some of the taste of the coffee.
    To help prove the point here are the comparable reading I got on TDS meter of the various water types:
    Bottled Spring water = 150ppm - depends on the brand
    Adelaide Mains water = 220ppm - lowest reading but it goes higher
    RO water = 19ppm - never goes higher but has been as low as 11ppm
    Filtered water readings vary, depending on the type/stage of filters use but it floats between bottled and mains.
    bearing in mind Saeco recommend you only use spring or filtered water for the life of the boiler
    .....but hey its just another aspect in helping to achieve a good coffee.
  • james
    Re: Coffee Machines
    I have owned four Saeco machines over the years. They specialize in the pressurized portafilter -- where there is a hing and a valve in the portafilter, so do you don't have to tamp. It's automatic, and it gives a very consistent shot. The pressure builts to the right point, then you hear a little "pop" and the coffee comes through. Interestingly, it can bring a crema out of a less fine coffee grind -- where tamping just won't do it.
    A dealer here told me the Saeco and Gaggia are now the same company. It's just brands, and they are huge here.
  • jahysea
    Re: Coffee Machines
    Originally posted by michael View Post
    Hello JC
    I think I've seen a Saeco while visiting a customers home, is this machine capable of both filter coffee and espresso?
    Hi Michael,
    The Saeco I have is their lowest end "Vienna" model, and it only does steam brewing. It grinds, tamps, forces a variable amount of steam, then ejects the grounds into a hopper and is ready to start another cup. You can set the spacing of the burr grinder and the amount of water/steam, that's no other adjustments.
  • Bacterium
    Re: Coffee Machines
    michael...nice work
    we have a great coffee shop in our city market that sells the largest local range of fresh beans. I've tried a few blends now and am learning a lot and can now work out what I like and why...... I like something along the line of what they call a "Columbian" and "Italian Espresso"...
    This all sounds a bit like appreciating wine.....there are a whole heap of "taste dimensions" to it.
    Bearing in mind I have a number of wine regions all within 2 hours drive from my house ....
    ....my fave a cool climate Cab Sav.
  • noosab
    Re: Coffee Machines
    Always mellow, never bitter.
    Put some water in a can, pot, whatever, add some ground or crushed coffee beans, heat and stir just before it boils to prevent foaming over, simmer or boil for 5 to 10 minutes, remove from heat and let rest for a few minutes or add a small amount of cold water and count to 30. Much better flavor than pressed and much more flavor per bean than filtered.
    Earl
