Heat stop
  • Les
    • Sep 2005
    • 2945
    Heat stop
    I just got a quote for a 50lb bag of heat stop - 300 plus dollars!!! I'm thinking that's pretty absurd.
    Les...
  • DrakeRemoray
    • Mar 2006
    • 1215
    Re: Heat stop
    You can get it shipped to you for less that that for sure!
    My Oven Thread:
    • RCLake
      • Jul 2007
      • 433
      Re: Heat stop
      Try the rumford website at HeatStop
      They list it for $50 plus $35 shipping. They also have a dealer in Carson City - Carson Masonry that you could try.
      By the way, I'm planning on a 42" and will taper the bricks to reduce mortar usage, I was wondering on how many bags I may use?
      RCLake
      "It's time to go Vertical"
      Oven Thread
        Re: Heat stop
        If you can get it locally, you should buy one bag at a time because it does have a tendency to wick out humidity and develop lumps. I used one bag, but I cut everything. A semi cut oven (brick sides cut, but not tapered) should use two or three, depending on how deep you lump it up. I don't think you need to mortar all four inch depth of a half brick oven, in other words leave it a little porcupine like.
        • Les
          • Sep 2005
          • 2945
          Re: Heat stop
          Thanks RC - Carson Masonry is where I got the absurd quote. I?m thinking that it was for a pallet or a larger quantity. Or they may be running with the Barnum and Bailey mantra. In regard to how much we need, not sure. I was going to buy two bags and go from there.
          Les...
