Clock Question
  • #16
    Re: Clock Question
    Not sure about using nail varnish remover. You need to be quite careful because I bet that it would take off any sealer(urethane) that you had laid on it. In one house we just stained the wood and then 2x a year used carnuba wax on it.
    Yep this thread is definately hijacked but hey it is in chit-cahat so it is all good
    • #17
      Re: Clock Question
      As long as you aren't starting your WFO fire with nail varnish remover...
      • #18
        Re: Clock Question
        Sorry. But enquiring minds want to know!
        • #19
          Re: Clock Question
          Dmun
          as per usual, I had a close look inside the clock movement and checked out the hammers and mechanism used to control them. I didn't detect any attempt to allow them to strike, ie no movement at all and no bar stopping them from striking. The other hammers would strike the Westminster in the quarter hour, so if the 'silent' lever was in place, Which incidentally we never use, then these would not work also.
          Anyway, it is in the hands of a person who has been maintaining it for the past 20 years and I guess I am at his mercy. I only ever give anyone one chance to screw me and it will be his last if he tries. He has put up a realistic explanation and nothing lasts forever. 30 years is fair to expect.
          A replacement mechanism that he showed me was around 1/3 the original size an so I am going with a rebuild. As you said previously, good quality tools and equipment will give you better longer and more reliable service than the cheap equivalent.
          Neill’s Pompeiii #1
          Neill’s kitchen underway
          • #20
            Re: Clock Question
            Dmun - you nailed it. 5 hammers. German made - my ex's in-laws gave it to us as a present while he was workin near Frankfort with the US Gov.
            Beautiful sound when it worked. Seems silly that it didn't have any name on the face.
            I'll tinker with it perhaps. Probably won't pay to have it fixed.
            My brother got the antique family clock after mom and dad passed. It's a really cool one with a dome over the top. I think you'd appreciate it. I'll see if I can get him to take a pic of it. I've never seen one like it.
            GJBingham
            • #21
              Re: Clock Question
              Originally posted by nissanneill View Post
              ... A replacement mechanism that he showed me was around 1/3 the original size an so I am going with a rebuild...
              Size isn't everything, as is oft said.
              At least he didn't suggest that you "modernize" to a battery-operated quartz movement. That happens too often and really upsets me.
              • #22
                Re: Clock Question
                Can I switch this back to dental floss. :-)
                I read an investment/retirement book a while back (It's called The Number and I recommend it), and the writer tells the story of a guy who does not floss in order to make sure he never outlives his money! It sounds like there is a strong correlation between flossing and living long (or at least avoiding some terrible things that happen to you as you get much older), so this guy considered not flossing as part of his long term retirement strategy. Very funny. Live fast and die old (but not really, really old).
                Pizza Ovens
                Outdoor Fireplaces
                • #23
                  Re: Clock Question
                  floss then brush
                  I brush then mop....
                  Sharing life's positives and loving the slow food lane
                  • #24
                    Re: Clock Question
                    I forgot about that question. Probably somebody did a study on just that topic. I don't know if there is a correct answer. I was taught brush then floss when I was young. About 20 years ago I swiched to floss then brush. Seemed like it made more sense to sweep out the corners of the kitchen first before doing the main floor. Otherwise your just sweeping the dust from the corners over the main floor areas you've already swept.
                    James, that correlation is correct, but is mostly due to healthy vs. unhealthy lifestyles in general. People who take care of themselves tend to live longer.
                    GJBingham
                    • #25
                      Re: Clock Question
                      I seem to recall a study a few years ago that drew a relationship between gingivitis and heart disease. It was a correlational relationship, from which causality cannot be inferred, but it is an interesting notion.
                      • #26
                        Re: Clock Question
                        Brian,
                        That's it. I've flossed ever since.
                        Pizza Ovens
                        Outdoor Fireplaces
                        • #27
                          Re: Clock Question
                          Yes, that has do do with the chronic low grade bacterial infection of the gingivae (gums) aka periodontitis (gum disease vs. gingivitis (inflamed gums)) actually causing infections in other parts of your body. There is certainly a concern for patients having valvular heart disease, joint implants, and a number of other disorders. Periodontal disease is the acutal breakdown of the bony attachment of the teeth to the surrounding bone and soft tissues and is more likely related to the disucussion above. The number of yeast double every twenty minutes in refreshed sourdough dough. You really don't want to know that the same thing happens in your mouth 20 miutes after a good meal. The numbers are staggaring when you culture them. Millions of bacteria per mm of saliva in a dirty mouth. Yukies! Better not to think to hard about that!
                          I know you were never told, but you really get most of your dental conditions from your parents. There's no such thing as soft teeth (except in a couple1:100,000 genetic conditions). Parents give their kids the oral bacteria that they will live with the rest of their lives. If parents have caries (cavities) they pass on Strep Mutans through saliva to their kids. If parents have gum disease, they pass on those nasty bugs as well. Caries or periodontal disease - rarely do you ever see both at the same time. Tooth brushing and flossing can stop the majority of both of these problems from really taking hold, as the problems occur when the numbers of bacteria overcome the body's defenses.
                          To the average Joe, if you get gum disease, your parents had it (shared their food and drinks with you, kissed you, etc.) and your body's genetic makeup predisposes you to that disease. Your teeth get loose, they fall out, the immune system fights off the local chronic infection (and actually causes some of the destruction itself). The immune system does a wonderful job keeping the battle against bugs a local event. A few bacteria do make their way into the bloodstream and have to ability to attach themselves to prosthetic heart valves, prosthetic joints, malformed heart tissues and other tissues that are at risk.
                          If your parents had caries, all you had to do was brush, floss and eat a diet low in sugar, starches and sticky foods to keep the S. Mutans at bay. A much easier problem to deal with. Xylitol based gums and products acutally inhibit these bacteria and allow more normal bugs to take hold in your mouth. Five times a day for 10 days a couple times a year. I'm getting rusty on the facts. I quit - remember?
                          Cavities and Periodontal disease are both bacterial infections. As you can imagine, there have been proposals for innoculations that establish non-invasive bacteria into the mouths of children/infants, which would once established, would provide an (almost) immunity to these diseases. Opponents, such as anti-flouridationist and other businesses (Such as toothpastes and oral rinses) who might loose market share will not support (lobby against) removing caries and periodontal disease from the population. Sad, huh?
                          On the other side, genetics is something you're born with. Some people are more predisposed to periodontal disease than others. Flossing every day with them slows the progress, but it continues relentlessly. Even with rigorous surigical therapies, they get worse. There's some nasty bugs out there looking to invade your mouth!
                          I'm sure that will make you sleep a little less easy tonight! Sweet dreams!
                          BTW - no mas! That's the last of the dentistry from me. I don't do that gig anymore. Now I make pizzas and bake bread! Happy happy!
                          GJBingham
                          • #28
                            Re: Clock Question
                            Thanks Professor George
                            • #29
                              Re: Clock Question
                              Yes thanks George - for the info and for sparing us any more of it... Still its the first time I've been glad to have Caries. Nothing like positive thinking, eh?
                              • #30
                                Re: Clock Question
                                Thanks for all of that information! I seem to recall a similar discussion long ago with a former dentist of mine, but I was a child and (a) didn't believe him, and (b) didn't fully understand the consequences. I now read, "hear", and understand the message. Why don't you bill my insurance for a "routine visit" -- that should help keep you going in your new venture.
