***Heating The House***
  • ThisOldGarageNJ
    • 1436
    Hi All,
    Was discussing this in another thread, Had I the forethought, I would have put my WFO in the house, or connected, Maybe ?
    Question Now is, Has anyone come up with a way to alter a WFO to possibly pump heat into the house over the winter,
    My first thought would be a copper pipe system, Insulated of course, to a radiator ? I know there has to be some kind of pressure relief ?
    My Thoughts are to put a cast iron radiator/kettle ? in the oven and pipe hot water to the house to another radiator ? I would keep a live fire in the oven I would open the pipes and let the water circulate after the cooking so as to not draw off too much heat from the cooking time...
    Maybe just a pipe dream ? But would love to hear some thoughts as I can get wood way cheaper than natural gas.....
    Thanks for endulging me.
    Mark
    • 9215
    Re: ***Heating The House***
    Build a new oven inside.
    • EADavis
      • 80
      I heard a rumor at work here that there is a restaurant in Carmel (CA) that had pipes run from their WFO to heat the outside patio. Unfortunately, I did not get the name of the restaurant or contractor who did it. But it sounds doable.
      Ed
      • Archena
        • Apr 2007
        • 1214
        1) Use a heat exchange (which is pretty much what you're describing).
        2) Build one of these: The Masonry Heater Association Home Page - Information on masonry heaters, manufacturers, and masonry heater builders (Better yet, get one built. They are tricky)
        [/CENTER]
        • ThisOldGarageNJ
          • 1436
          This is the kind of Item im looking for, Found on ebay for 149.00,,,, Now its gonna take some time for reading, planning Making sure I dont blow the house up, Etc,,,,
          Mark
            The English, who often used their Aga and Rayburn cookers as house heaters, had quite a complicated loop system, with an expansion tank, between the in-cooker coil and the room radiator. I think you need to keep the water circulating even when you're not calling for heat. These cookers were kept burning all day and all night: Do you use your oven enough to justify this complicated plumbing system?
            Also, don't forget the redneck pool heater:
            Anything is possible...
            • ThisOldGarageNJ
              • 1436
              David,
              First off is the redneck pool heater for real,,, Do I use the oven enough to heat the house ?, No,,, But I think I heat the house enough to use the oven for cooking..Im not trying to be a smart a**.... Just trying to get some more bang for my buck... I have a large amount of free wood available yearly, and my thoughts are if I can heat the house without hurting the oven or maybe build an outdoor fire box/heater it might be worth my while....
              Mark
              • brokencookie
                • Oct 2007
                • 376
                Originally posted by ThisOldGarageNJ
                David,
                Mark
                Is this it ?
                It probably goes with the Redneck grill in the next picture
                • Les
                  • Sep 2005
                  • 2945
                  Why not just put in a wood burning stove? Mine works great. It would be easier and a hell of a lot less $$.
                  Les...
                  • RTflorida
                    • Jan 2007
                    • 1446
                    I think I saw an infomercial on that first pic......they were calling it the Drunken Dumb ASS Burner; or was it the Drunken DUMBass burner?...can't remember which.
                    Gives new meaning to "chestnuts roasting on an open fire"
                    RT
                    • ThisOldGarageNJ
                      • 1436
                      Just trying to make use of what I Had and Would prefer to have something outside the house for safety reasons,, I was a volunteer FF, Rescue Squad and Haz Mat Tech. for over 10 years, I have seen first hand what can happen in a fire that is left un attended, I know most wood stoves now have upgraded their safety levels incredibly, Just would feel better if it was away from the house,,, I hope I will get to it this year,
                      I found a few other sites with some good info, so I can read up more over there... where they are more familiar with this kind of thing,
                      As I said I have an almost unlimited wood supply, My money supply is not as good.... So If I can get heat and hot water out of a system, might be a great thing,,,
                      Mark
                      • ThisOldGarageNJ
                        • 1436
                        P..S.. Dmun and brokencookie,
                        Where did you find those pics, They are hysterical,, Should re post them in humor. Or can you move them over there david ?
                        Mark
                          I caught hold of that picture years ago on here: it must be pretty popular, "redneck pool heater" popped up pretty quickly as a suggestion when I started typing on google images.
                            • 9215
                            Check out the redneck hot tubs via google
                            • brokencookie
                              • Oct 2007
                              • 376
                              You can find all kinds of handyman fixes and failure pictures on these sites
                              There, I Fixed It: Epic Kludges + Jury Rigs
                              FAIL Blog: Epic Fail Pictures and Videos of Owned, Pwnd and Fail Moments
                              Try not to hurt yourself laughing
