refractory concrete
  • Flabuck
    • Nov 2009
    • 15
    refractory concrete
    Does anyone know of an alternative mix for refractory concrete not using calcium aluminate cement?
  • nissanneill
    • Apr 2007
    • 1886
    Re: refractory concrete
    Flabuck
    The so called 'poor man's mortar' is 1 part portland, 1 part hydrated lime, 1 part fireclay and 3 parts brickie sand.
    This mix is quite 'stickie' and holds the cut half bricks beautifully in place to almost vertical position so is ideal for non-form work dome building. My dome is over 2 years old and has no cracks so I recommend this to all builders. I would not use anything else.
    Check out my build, there are many pics, tips and tricks that I found during my rather quick build, ie. the dome and hearth built in 2 wet days. Then came the outdoor kitchen.
    Cheers.
    Neill’s Pompeiii #1
    Neill’s kitchen underway
    • Flabuck
      • Nov 2009
      • 15
      Thanks for the info on that mix Neill,I'll try it the rest of the way.Do you think I could use a similar mix and add either crushed fire brick or river rock to make concrete?I have a guy who wants me to build him an oven and I was thinking about forming the chamber walls and pouring them. Thanks!
      • RTflorida
        • Jan 2007
        • 1446
        You are going to need a castable refractory cement. I am not aware of anyone using a 'home brew' to cast an oven, whether done in sections or as an entire dome.
        Do s forum search of castable ovens, there are several good threads here on the forum from folks who have either cast their ovens in sections or as a whole, but again, they used a premixed castable.
        RT
          Any amount of portland based concrete, other than the home-brew mortar between bricks, is a recipe for disaster. A recent thread (of many) on the topic:
          Firebricks are cheap in the US. There's no reason not to use them.
          • nissanneill
            • Apr 2007
            • 1886
            Flabuck
            I wouldn't use the mortar mix for a concrete nor as a refractory castable material.
            I used it very successfully for the mortar joints in my Pompeii but that is all I would use it for. No need to use different and expensive refractory adhesives for thinner than 3mm joints and a different one for thicker joints as many of mine went from 1mm to 12-15mm thickness with not one crack as yet on over 2 years. You will need to buy the expensive refractory material to cast an oven dome, or buy one of James's special budget models.
            Neill’s Pompeiii #1
            • Flabuck
              • Nov 2009
              • 15
              Thanks for all the info guys it's a big help.I just have one more question.I know how tall an ovens opening should be in relation to the chamber height but what about the width?I am building a 32 by 36 oven (16 inch chamber height) with a 10 inch opening height and would like to make it about 22 inches wide.Would this lose to much heat?Again,thanks for taking the time to respond to my questions.
              • ThisOldGarageNJ
                • 1436
                Hi Flabuck,
                My oven is a 42 inch pompei,, My door is 22 wide... I dont think the width is of too much importance as long as you have your dome height to door height ratio correct (.63) I just wanted to make sure I could slide a big a$$ pan thru the opening...
                Mark
