Does anyone know of an alternative mix for refractory concrete not using calcium aluminate cement?
Re: refractory concrete
Flabuck
The so called 'poor man's mortar' is 1 part portland, 1 part hydrated lime, 1 part fireclay and 3 parts brickie sand.
This mix is quite 'stickie' and holds the cut half bricks beautifully in place to almost vertical position so is ideal for non-form work dome building. My dome is over 2 years old and has no cracks so I recommend this to all builders. I would not use anything else.
Check out my build, there are many pics, tips and tricks that I found during my rather quick build, ie. the dome and hearth built in 2 wet days. Then came the outdoor kitchen.
Cheers.
NeillPrevention is better than cure, - do it right the first time!
Neill’s Pompeiii #1
Neill’s kitchen underway
Thanks for the info on that mix Neill,I'll try it the rest of the way.Do you think I could use a similar mix and add either crushed fire brick or river rock to make concrete?I have a guy who wants me to build him an oven and I was thinking about forming the chamber walls and pouring them. Thanks!
You are going to need a castable refractory cement. I am not aware of anyone using a 'home brew' to cast an oven, whether done in sections or as an entire dome.
Do s forum search of castable ovens, there are several good threads here on the forum from folks who have either cast their ovens in sections or as a whole, but again, they used a premixed castable.
RT
Any amount of portland based concrete, other than the home-brew mortar between bricks, is a recipe for disaster. A recent thread (of many) on the topic:
http://www.fornobravo.com/forum/f8/p...vers-8636.html
Firebricks are cheap in the US. There's no reason not to use them.
Flabuck
I wouldn't use the mortar mix for a concrete nor as a refractory castable material.
I used it very successfully for the mortar joints in my Pompeii but that is all I would use it for. No need to use different and expensive refractory adhesives for thinner than 3mm joints and a different one for thicker joints as many of mine went from 1mm to 12-15mm thickness with not one crack as yet on over 2 years. You will need to buy the expensive refractory material to cast an oven dome, or buy one of James's special budget models.
NeillLast edited by nissanneill; 11-09-2009, 03:51 AM.Prevention is better than cure, - do it right the first time!
Neill’s Pompeiii #1
Thanks for all the info guys it's a big help.I just have one more question.I know how tall an ovens opening should be in relation to the chamber height but what about the width?I am building a 32 by 36 oven (16 inch chamber height) with a 10 inch opening height and would like to make it about 22 inches wide.Would this lose to much heat?Again,thanks for taking the time to respond to my questions.
Hi Flabuck,
My oven is a 42 inch pompei,, My door is 22 wide... I dont think the width is of too much importance as long as you have your dome height to door height ratio correct (.63) I just wanted to make sure I could slide a big a$$ pan thru the opening...
Cheers
Mark
