I'm in desperate need of cheap, temporary storage. I came across a chicken coop that I want to build but I'm not sure of the bottom frame.
The plans are here: https://mail.google.com/mail/?shva=1#inbox
You can see the horizontal bracing. I plan on actually putting in a floor - probably nothing more than some 1x6 or 1x8's tacked down since it isn't going to be permanent by any means. I'm pretty sure the flooring will dispense with the need for diagonal bracing but I'm not positive. Is the bracing there for anything other than to prevent racking?
Thanks, guys!
Thanks, guys!
