Roof Insulation
  • Archena
    • Apr 2007
    • 1214
    Roof Insulation
    I'm trying to think of a cheap way to insulate a metal shed roof. I want to use one as a place for the dogs to go when it's cold. I was thinking of using straw bales to insulate the walls (on the outside to prevent accidents) but that would only rot out the roof faster. I suppose I could put half bales on the roof and then a roof atop that but that's a lot of work for something I don't want to spend a lot on. A tarp might work but would probably get blown off in the first thunderstorm.
    Eventually, I'll build a cob shed to replace it - which wouldn't have the same problems. But I doubt I will get it done by next winter so I'm trying to think of something cheap that will work for a year or two.
    [/CENTER]
  • david lyons
    • Nov 2010
    • 19
    Re: Roof Insulation
    hi
    the gold miners at kiandra in the 1850's lived in tents. they had a fly ie a tarp as a second roof over the tent and stuffed the space between the tent and fly with brush.
    kiandra gets very cold, it is actually the birthplace of skiing in oz. i have seen it with snow drifts up 20 feet deep.
    just a thought
    dave ly
    • Archena
      • Apr 2007
      • 1214
      Re: Roof Insulation
      Hi,
      Thanks! it's actually a good thought - and really interesting to know. But we get a lot of thunderstorms here so I'll have to figure out a really good tie down - still not a bad idea at all and something I could easily redo when it got wet.
      [/CENTER]
        • 9208
        Re: Roof Insulation
        If it were mine I'd fix metal studs to the inside against the walls, infill with fiberglass insulation then sheet it. The same for the roof. But this would be some expense, not exactly a really cheap option.
        • Archena
          • Apr 2007
          • 1214
          Re: Roof Insulation
          If I were doing something permanent, that sounds like the way to go. but I'm planning on buying something cheap just to get by with for two years max - hopefully no more than one. Long term, I want to build permanent dog houses from cob. With good baffles and insulation, they should be more than warm enough for anything north of zero.
          [/CENTER]
          • Roderick H
            • Jan 2013
            • 2
            Re: Roof Insulation
            Yes, building a permanent shed would be the best solution. But for the time being I'll suggest you to go for fiberglass insulation. Moreover, you can also checkout SIPs material.
            • medeekgil
              • Nov 2014
              • 1
              Re: Roof Insulation
              Build a permanent shed would be the best solution.
              • fornax hominus
                • May 2009
                • 157
                Re: Roof Insulation
                Try going to a cabinet shop and scrounging big sheets of bubble wrap .. 2 layers gives you a good temp. insulation .. out of the sun they last . Fiberglass gets riddled with mice and squirels unless you seal it off 100% with solid wood or metal . -13c today in the valley , how cold can it get in 'Bama ?
                Last edited by fornax hominus; 12-04-2014, 06:05 AM. Reason: hyphen not underscore !
                • Archena
                  • Apr 2007
                  • 1214
                  Re: Roof Insulation
                  It rarely drops below 20F here. This week nights are in the 30's - last week nights were in the 50's and days in the 80's!
                  The one constant about Alabama's weather it that it changes... Really fast!
                  [/CENTER]
