Installing my Premio2G100 and when I lay the FB board it is warped and has a bit of a spring to it. I thought setting the oven on would help to get it to lay flat, bit it didn't.
I layed the FB board, bedded with 3/8" of sand and set the floor as best as possible considering the FB board was so out of whack. Then after I set the oven I let it sit for a day. I then filled what I had for cracks with sand and tried to set the oven floor level with a rubber mallet and more sand where needed, but it won't level up.
When I push down on the side of the FB board I can actually see it move and the oven flexes with it.
Has anyone had this issue? I'm hoping not to have to pull the oven off (no mortar yet) and really hoping not to have to go back and pour vermiculite.
Any help would be appreciated and paid back to the next member that needs help.
Thanks! Bob
Thanks! Bob
