Do I need a footing?
  • ryawuerf
    • May 2015
    • 1
    I am planning to build an oven that will sit on a steel structure. Can the steel structure sit directly on my paver patio, or should I pull up some pavers and pour a slab with some deeper footings?
    My thought is if I design the steel structure properly it can distribute the weight and sit right on the pavers. I realize that this is a very important step and I don't want to screw it up. Any thoughts that anyone could help with is greatly appreciated.
  • RandyJ
    • May 2010
    • 1191
    Re: Do I need a footing?
    If you were on a concrete patio I would say you were safe but pavers you will want something a little more solid . Good luck on your build.
    Randy
    • okn
      • May 2011
      • 133
      It depends on the size of the oven and the design of the stand. I personally think it can easily be done on pavers.
      • RandyJ
        • May 2010
        • 1191
        Well I guess I could depend on the type of stand and type of oven. I was thinking of just 4 feet comming down but if you had a square on the bottom same as the top to spread the weight out you might be just fine as long as the patio was properly built. I for a moment was thinking of my oven that I think weighs north of 10,000#.
        Randy
