Concrete slab question
  • ThisOldGarageNJ
    • 1436
    #16
    Re: Concrete slab question
    Go there very early in the morning and you'll find lots of damaged bagged goods outside on palets, discounted, everyday.......like 90lb bags of concrete mix for a buck each.
    Hey thats a great tip,, wish I knew that before.. I think you need to hire a day laborer for a day or two,, although you are saving a lot onn a gym membership
    Mark
    • fxpose
      • Jul 2009
      • 942
      #17
      Just this morning we picked up a palet load of goods for $15. The only thing is you've got to buy everything that's on the palet.....which included 6-50lb chunks of solid roofing tar which I have no use for. But we ended up with close to 8 complete bags of 90lb mix, almost 5 complete bags of 60lb mix, and about 5 torn bags of 3/4" gravel.
      I now carry large trash bags with me so loading some of these torn bags of concrete would be less messy loading them into the SUV.
      George
      My 34" WFO build
      • ThisOldGarageNJ
        • 1436
        #18
        wrap the tar in plastic and use it for fill....
        • fxpose
          • Jul 2009
          • 942
          #19
          Brilliant!
          George
          My 34" WFO build
          • ThisOldGarageNJ
            • 1436
            #20
            Hey F,,,
            Fid you remove the post from the picture,, Is there a roof over the area.. ??
            Any progress ??
            I know your stockpililng
            CHeers Mark
            • fxpose
              • Jul 2009
              • 942
              #21
              Hey F,,,
              Any progress ??
              CHeers Mark
              Thanks Mark,
              No, those 6x6 posts support a small deck and roof up above, just outside the dining room.
              So far, I've dug most of the trenches, built forms around them, and layed rebars. I 've got more than enough concrete mix to fill them. I'm just waiting for my concrete mixer which I ordered a week ago to get here.
              George
              George
              My 34" WFO build
              • fxpose
                • Jul 2009
                • 942
                #22
                I poured the footings over the weekend. I think I used about a yard of concrete on two separate pourings as I dug pretty deep. I didn't get the mixer yet so it was the old wheelbarrow......good thing I had a friend help me out doing the mixing...
                George
                My 34" WFO build
                • ThisOldGarageNJ
                  • 1436
                  #23
                  Your off to a good start,, I see you havent made the giant bathtub into a garden shed yet,,, or maybe bomb shelter....
                  • fxpose
                    • Jul 2009
                    • 942
                    #24
                    I plan on just dry-stacking, re-barring the blocks, and filling most of the cores with concrete but is it necessary to mortar the first course onto the footings? I need to dead level the first course anyway so using mortar makes sense.
                    That giant bath tub situation is still up in the air....
                    George
                    My 34" WFO build
                    • Neil2
                      • Oct 2006
                      • 1374
                      #25
                      "And for extra measure, to prevent eventual sinking or tilting of the slab, I will drive rebars into the existing rear and right side block foundation,"
                      I would advise against this. Keep the new slab and footings independent of the existing foundation walls. If not, any movement or settlement of the new works could damage the existing walls. Put a 1/2 layer of felt/fiber material against the existing walls prior to pouring.
                      • fxpose
                        • Jul 2009
                        • 942
                        #26
                        Hi Neil2,
                        Thank you for your reply. What you're advising makes a lot of sense. I'm going to rethink this carefully.
                        George
                        My 34" WFO build
                        • Archena
                          • Apr 2007
                          • 1214
                          #27
                          I'm reminded of something the Lord once said about new wine in new wineskins...
                          [/CENTER]
                          • fxpose
                            • Jul 2009
                            • 942
                            #28
                            More progress. During the week I mortared the first course to the footing and just yesterday I laid horizontal rebars and stacked the rest of the blocks.
                            I will toss in a few vertical rebars and fill most of the cores this week.
                            So far, this has been a great practice project for me before moving to the larger patio/WFO project.
                            George
                            My 34" WFO build
                            • ThisOldGarageNJ
                              • 1436
                              #29
                              this is definitely an ambitious project... looks great so far.....
                              Mark
                              • fxpose
                                • Jul 2009
                                • 942
                                #30
                                Thanks again!
                                Do you guys think I should fill every core or can I get away with filling every other? I know the cores can use up lots of concrete. Thanks!
                                George
                                My 34" WFO build
