Concrete slab question
  • fxpose
    • Jul 2009
    • 942
    #61
    Re: Concrete slab question
    This morning I nailed in a few support braces for the plywood form. I think this is plenty support to handle the weight of the concrete pour. I will also prop a couple of 2x4's under it.
    Tomorrow, I plan on laying down some plywood, form rebars on top, erect perimeter forms, and pour the slab.
    I have one question though: Should the center block column tie directly in with the slab or should the slab simply rest on the column and be independent of one another in case of settling? I could cut the column rebars and cover the top of the column with a piece of plastic sheeting before pouring the slab if they were to be independent.
    George
    My 34" WFO build
    • Neil2
      • Oct 2006
      • 1374
      #62
      What does this centre column do ?
      In any case, I would isolate it from the triangular slab. Connecting it structurally to the slab will induce all kinds of stresses and it will likely produce cracks.
      Don't forget to allow for drainage of the "void" under the slab.
      • fxpose
        • Jul 2009
        • 942
        #63
        That's a good question.
        Having never done this type of construction before I thought the center column would give additional support but figuring the slab will be supported by sitting on top of the foundation walls on all three sides, why would I need it, considering the small area involved? There will be plenty of rebars also, so on second thought perhaps there was no need for this center column to begin with.
        I'll probably just remove the top three blocks of the column as those cores are not filled yet and cut the rebars. I'll just add an additional wood bracing across the middle there...
        George
        My 34" WFO build
        • ThisOldGarageNJ
          • 1436
          #64
          fx,
          after looking at the pic again,, that is not a tremendous span.. in my opinion you could surely leave it out.. with the rebar you should be good to go.. and like neil said it may add too many additional stresses.... and most of us have enough stress already (snicker)
          Keep going
          Mark
          • fxpose
            • Jul 2009
            • 942
            #65
            Thanks guys! Early this morning I removed the column, added additional joists, and nailed down the bottom plywood form.
            George
            My 34" WFO build
            • fxpose
              • Jul 2009
              • 942
              #66
              I think prepping for a suspended slab was far less labor intense than filling and tamping/compacting that area will fill material.
              George
              My 34" WFO build
              • ThisOldGarageNJ
                • 1436
                #67
                Hey FX,
                Looks good and I dont think your gonna get it any more solid any other way, Nice job tying it all together.. When you pouring ??
                • jmhepworth
                  • Feb 2008
                  • 293
                  #68
                  Nice job with the steel. It's nice to see I'm not the only one to over-engineer that part.
                  Joe
                  • fxpose
                    • Jul 2009
                    • 942
                    #69
                    Thanks guys! So far, I'm pretty happy with the way things are turning out. I will be pouring concrete today and contunue work in the next area.
                    I am just glad I'm not paying someone else to do this job. Concrete and blocks are cheap, but I'm spending a whole lot more money on rebars.
                    George
                    My 34" WFO build
                    • fxpose
                      • Jul 2009
                      • 942
                      #70
                      Another slab down...
                      George
                      My 34" WFO build
                      • ThisOldGarageNJ
                        • 1436
                        #71
                        is there anyone under that slab ??? Looks good man... only how many to go till you get to the oven ??
                        Nice job
                        Mark
                        • Archena
                          • Apr 2007
                          • 1214
                          #72
                          Nice job
                          Mark
                          Hmmmm, ya know, I haven't seen RT all day...
                          Congrats on the purdy concrete, FX!
                          [/CENTER]
                          • RTflorida
                            • Jan 2007
                            • 1446
                            #73
                            Hey now!!!
                            Although that was well deserved and Jimmy Hoffa WAS like a father to me, I wouldn't be caught dead (pun totally intended) wearing a pair of cement shoes after Labor Day.
                            RT
                            • ThisOldGarageNJ
                              • 1436
                              #74
                              We all know "jimmy" will be at the Giants game today
                              Mark
                              • Archena
                                • Apr 2007
                                • 1214
                                #75
                                Ouch! Too bad FX didn't bury those puns while he was at it...
                                [/CENTER]
