My 3-Legged Dome
  • Neil2
    • Oct 2006
    • 1374
    #61
    Re: My 3-Legged Dome
    Here is what I used for my inner mold (available cheap $5-$6 and in many sizes from any heating supply place):
    • fxpose
      • Jul 2009
      • 942
      #62
      Neil, I looked for that exact vent but couldn't find it anywhere. If it was available to me I certainly would have gone that route instead of casting one from scratch.
      Where did you get yours?
      George
      Edit: I found the website where they have these vents in various sizes. I searched for floorboxes. My search a few weeks ago led me nowhere as I had no idea what they were called. Yes, I could have used one of these instead.
      George
      My 34" WFO build
      • Neil2
        • Oct 2006
        • 1374
        #63
        They are used in heating ,ventilation and air conditioning ducts. Look up HVAC on your local business directories.
        • fxpose
          • Jul 2009
          • 942
          #64
          My vent is cast
          I just removed the forms off the vent. This sucker is hefty.
          George
          George
          My 34" WFO build
          • fxpose
            • Jul 2009
            • 942
            #65
            Mounted the vent.
            As you can see in one of the photos I placed a piece of left over 3" ceramic board and some temporary bricks on the top of the dome to see if they'll work as support for the chimney pipe. The pipe and the support will all be buried in vermicrete.
            The chimney will exit straight out middle of the dome.
            George
            George
            My 34" WFO build
            • fxpose
              • Jul 2009
              • 942
              #66
              First fire and smoke test
              I burnt a Dominos pizza box this evening to check for smoke, running a temporary 48" stove pipe. The vent drew well with this small fire. But of course, I have no idea yet how well it will vent with a roaring fire.
              George
              George
              My 34" WFO build
              • Dino_Pizza
                • Feb 2008
                • 1036
                #67
                Burn the Dominos box! Yah .
                George, you make casting a vent look easy. It really doesn't seem that much harder than cutting lots of brick or clay pipe or even fitting metal pipe. It's a good option that can solve lots of problems. Glad you did it.
                -Dino
                My Oven Costs Spreadsheet
                My Oven Thread
                • leckig
                  • Aug 2009
                  • 99
                  #68
                  This thread is very interesting to follow. So much creative thinking. Thanks George and congratulations!
                  my own Quest for Fire:
                  http://www.flickr.com/photos/leckig/
                  • fxpose
                    • Jul 2009
                    • 942
                    #69
                    Thank you Dino and leckig.
                    The clay sculpting and ceramics classes I took in community college many many years ago certainly helped make casting the vent an easy task.
                    The round front profile and the very shallow entry of the oven have been slowing me down at this stage. Also, I will be making some changes to the outer entry as I feel it is a bit too splayed/flared out. I intend to bring them in a bit, but not affect the inner opening.
                    George
                    George
                    My 34" WFO build
                    • turkey
                      • Apr 2010
                      • 39
                      #70
                      looking very nice, thoes casts look as good if not better to the commercial ones
                      when you say the chimney will come right out the middle do you mean like here
                      MHA News - 2006 Meeting - Backyard Oven with Peter Moore
                      where the vent at the front then runs back over the top with a central chimney stack?
                      • fxpose
                        • Jul 2009
                        • 942
                        #71
                        Thanks turkey. Yes, the oven will have a central stack, the only difference being mine will be routed to the middle with a steep stove pipe before elbowing out the top.
                        George
                        George
                        My 34" WFO build
                        • Neil2
                          • Oct 2006
                          • 1374
                          #72
                          "mine will be routed to the middle with a steep stove pipe before elbowing out the top."
                          Curious as to why you are doing it that way.
                          Aesthetics ?
                          To get the stack back out of the way ?
                          • fxpose
                            • Jul 2009
                            • 942
                            #73
                            Aesthetics ?
                            The main reason for locating the stack a bit further back is to "hide" it from view from the street and the front of the house. As you enter the driveway most of the oven is tucked away in the nook except for the front of the oven which is visible. I did not want a tall smoke stack to become an eyesore as you entered into the driveway. The only part of the chimney you will see will be a short section at the very top and the cap.
                            A more ideal solution is to locate the stack way back in the corner of the nook, at the rear of the oven, but I did not like some of the drawings I did on that design.
                            George
                            George
                            My 34" WFO build
                            • fxpose
                              • Jul 2009
                              • 942
                              #74
                              I did not get much work done this week as I'm waiting for the rest of my chimney components to arrive. I should get them today.
                              Yesterday I narrowed the outer entry width by 3" and did a little cosmetic touch up surrounding the entry.
                              George
                              George
                              My 34" WFO build
                              • fxpose
                                • Jul 2009
                                • 942
                                #75
                                I did not want to waste any so I used up all of 50ft of 24" wide x 1" thick blanket....that's 100 sq/ft. I piled the remainder on top as you can see. The side walls have 3" of blanket and I think the top has about 6" worth.
                                George
                                Edit: BTW, the outside facing brick surfaces will be stuccoed as well. That's why I made them flush with the base.
                                George
                                My 34" WFO build
