My Oven/BBQ
  • christo
    • Feb 2006
    • 913
    #31
    Re: My Oven/BBQ
    Here's an alternate route about 3/4 of the way down the page. May not be what you want but may start some ideas....
    MHA News - 2006 Meeting - Backyard Oven with Peter Moore Has an oven that vents from the front to the back via a brick channel on top of the dome.
    This oven had a of the topics we've been talking about lately incorporated into it and then some.....
    Christo
    My oven progress -
    sigpic
    • Leepinla
      • May 2006
      • 62
      #32
      Re: My Oven/BBQ
      Yes I saw that, thank you, that?s what I was thinking about,
      But then the cleaning part came in.
      Looks like after some time,
      I will just have to clean it with a sledgehammer.
      AND THAT MEANS
      The next home owner will have to clean it (hahahahaha)
      I see that they sell a stainless steel flex pipe as a chimney liner.
      What about that kind? Ridged or flex, once it?s covered in refractory mud, then it?s a cement pipe? Or are the gasses that hot?
      I have looked at the oven and can settle on a more strait up designL
      But it dose not fit the vision.
      It?s raining here today, so I think I?m going to look into this chimney thing a little more. Any advice is as always most appreciated.
      Thanks.
      Leepin
      • Leepinla
        • May 2006
        • 62
        #33
        Re: My Oven/BBQ
        Its Done.....
        now I just sit and look at it
        For how long???????????
        heres some new pic's
        Leepin.
        • maver
          • Aug 2006
          • 571
          #34
          Re: My Oven/BBQ
          It appears you plan to apply a vertical chimney pipe at the rear end of that horizontal run. Will you temporarily apply the vertical pipe (perhaps with bracing wires or rods) and test the draw of your chimney prior to fully cementing in that horizontal run?
          • Leepinla
            • May 2006
            • 62
            #35
            Re: My Oven/BBQ
            yes I am, Maver,
            the run is only to the middle of the dome
            it's all going up, and looks like it will draw (from the smoke from my cig)
            but I plan on eatting before I insolate, so if its no good I will take it out and go strate up in the front like every other one.
            can I build a fire today???????????
            • jwnorris
              • Jul 2006
              • 231
              #36
              Fire in the hole ... [was] My Oven/BBQ
              Originally posted by Leepinla
              Can I build a fire today???????????
              But, of course. Follow the curing fire instructions and enjoy.
              J W
              • Leepinla
                • May 2006
                • 62
                #37
                Re: My Oven/BBQ
                Well then Here we go.
                • maver
                  • Aug 2006
                  • 571
                  #38
                  Re: My Oven/BBQ
                  That 3rd picture shows the smoke layered in the oven (before the temperature gets too hot for smoke as it will with your later fires) - I like it. Also, same picture, your oven entrance picture shows good work with the way you tapered up the vent, a good picture for other oven builders to look at. Now you are starting to have fun with fire! I bet as you get the oven hotter the chimney will heat up and draw more efficiently so you don't continue with the "leak" of smoke you have out the front opening as seen in the first picture.
                  • jahysea
                    • Oct 2006
                    • 116
                    #39
                    Re: My Oven/BBQ
                    More flue would help the draw as well. Is the plan still to go upward from the center with more chimney?
                    - JC
                    • beammeup
                      • Oct 2006
                      • 33
                      #40
                      Re: My Oven/BBQ
                      Sorry to bud in here but I have a question for JC. You say more flue would give a better draw? I have almost finished my oven , I am using 8" stainless pipe 1m vertical 45 deg joint then 1m on the 45 diagonal then 45 deg joint then 1m back up at the vertical. This is to go around an outdoor porch roof rather than through it. The pipe is fabricated but I havent put it up yet, do you think it will draw OK? My curing fires the smoke went up the vent (without the pipe) pretty good. I am a bit worried that with so much pipe and the diagonal it wouldnt draw well.
                      • Leepinla
                        • May 2006
                        • 62
                        #41
                        Re: My Oven/BBQ
                        #3 curing fire went well.
                        One small crack on the outside of the vent, (not bad)
                        After all curing fires I will fix the crack
                        The dome looks great (no cracking at all)
                        Bricks will burn clean todayJ
                        Leepin
                        • Marcel
                          • Aug 2005
                          • 426
                          #42
                          Re: My Oven/BBQ & taller vent is good
                          (B)
                          (M) I agree with a taller flue. Virtually every posting I've read also supports that view.
                          (B) I have almost finished my oven , I am using 8" stainless pipe 1m vertical 45 deg joint then 1m on the 45 diagonal then 45 deg joint then 1m back up at the vertical. This is to go around an outdoor porch roof rather than through it.
                          (M) I also had to jog, but for a different reason. I wanted to avoid contacting my ridge beam. Click below to see images of those flex elbows:
                          Post photos of your oven in-progress and when you are done, along with photos of pizza, roasts, bread and more.
                          (B) The pipe is fabricated but I havent put it up yet, do you think it will draw OK? My curing fires the smoke went up the vent (without the pipe) pretty good. I am a bit worried that with so much pipe and the diagonal it wouldnt draw well.
                          (M) Just the opposite. A taller chimney keeps a distance from your fire so that turbulence won't send smoke back down and smother your fire. Also, when the metal flue gets hot, it keeps the smoke rising.
                          (M) You may have some initial smoke out the front of your oven before the flue gets hot enough. Once you have a roaring fire you should have hardly any smoke, even out the vent!
                          (M) I will be attaching a metal shroud this spring to direct the smoke around the roof peak and when I do, I'll post pictures of it.
                          Ciao,
                          Marcel
                          • beammeup
                            • Oct 2006
                            • 33
                            #43
                            Re: My Oven/BBQ
                            OK thanks Marcel. Leepin what kind of clading is on the outside of your fire bricks? Concrete or some refractory material? That crack looks pretty substantial. How much time did you give it before your fires? I'm asking because I havent had any big fires in mine yet, so I'd like to try and avoid any cracks as I already applied the insulation layer (5"-6" vermicrete).
                            • Leepinla
                              • May 2006
                              • 62
                              #44
                              Re: My Oven/BBQ
                              The crack is superficial; it runs on the outside of the vent
                              I have no insulation on the outside of my oven yet.
                              So it will be easy enough to fix, plus my chimney pipe seems too small,
                              (Too much smoke out the door) so I think I am going to go with 6? pipe all the way up
                              it is now 6?X10?X6?to a 4?pipe X 5?
                              Will a 6? pipe work?
                              Leepinla
                              (pics to come)
                              • Leepinla
                                • May 2006
                                • 62
                                #45
                                Re: My Oven/BBQ
                                Ok, the crack was from the cold weather and a fire to soon. (I could not help myself)
                                So out come the hammer, Chip off bad cement, and put in a bigger flu. (6?)
                                Leepin
                                Here are some new photos before the mud it in.
