Let’s Roll! 40” Pompeii in Nanoose Bay
  • peterlyn
    • Nov 2008
    • 79
    #16
    Re: Let?s Roll! 40? Pompeii in Nanoose Bay
    eprante:
    Thanks for the compliments. It does look like a diving board, doesn't it? However, once the floor under the arch and the finished landing are poured, it will blend in at the same level.
    The outer arch will be made from precast concrete; the form is made and will be poured today. Of course, that's for the finished exterior so we've a way to go yet! Vent and dome work next.
    Rain stopped play over the weekend and we may have to get a canopy out to continue this week.
    Karen
    • pwcoppard
      • Jul 2007
      • 20
      #17
      Great looking oven. We would love to meet you - we built an oven in Calgary, and also have a house in Nanoose Bay - planning a build soon.
      • dtrbovich
        • Sep 2010
        • 61
        #18
        Wow....I hope my dome looks half as professional as yours. Good job!
        • peterlyn
          • Nov 2008
          • 79
          #19
          pwcoppard, Meeting-up would be great. Let me know when you're next in town (we lived in Calgary for 5 years) and we'll get together.
          dtrbovich, thanks for the kudos but Dave has been at it a loooong time! He says that dome was one of the most challenging masonry he's done, by the way, so hats off to the amateurs.
          Anyway, I'm going to continue the commentary under the Pompeii Oven Construction section - it just makes more sense. The thread is here:
          Karen
          • peterlyn
            • Nov 2008
            • 79
            #20
            Pics of the high-heat mortar coat on the dome.
            Karen
            Thread: http://www.fornobravo.com/forum/f8/p...bay-14633.html
            • peterlyn
              • Nov 2008
              • 79
              #21
              Pics of:
              Installing fibre/fiber blanket (2 x 1" thick), then covered with strand wire to hold in place, then covered in expanded lath (stucco wire), then regular cement coat.
              Karen
              More at:
              • peterlyn
                • Nov 2008
                • 79
                #22
                Pics of arch and vent.
                Start of chimney.
                Karen
                • peterlyn
                  • Nov 2008
                  • 79
                  #23
                  Forming and pouring the enclosure.
                  • peterlyn
                    • Nov 2008
                    • 79
                    #24
                    Forms off. Rest of enclosure (top) to be built of brick. Finish will be stone.
                    • peterlyn
                      • Nov 2008
                      • 79
                      #25
                      Enclosure continued:
                      Forms off. Brickwork continued and flue built.
                      Stucco coat applied to seal.
                      Waiting for cap & exterior stone of course.
                      3rd curing fire.
                      • peterlyn
                        • Nov 2008
                        • 79
                        #26
                        Decorative Arch:
                        Formed, poured and washed for exposed aggregate look.
                        Cemented to front of arch.
                        Stone and concrete counter will butt up against it at the finish.
                        Karen
                        • glowthb
                          • 35
                          #27
                          Thanks for the great photos and play by play on the build. I am getting ready to pour my hearth tomorrow and it was very beneficial to see your technique. I was thinking of using wood wedges to support the dome bricks, partially mortar, and then remove them. I like the idea of the brick wedges and leaving them in place and mortaring around them.
                          I will let you know how it goes and share pics.
                          Thanks again.
                          • peterlyn
                            • Nov 2008
                            • 79
                            #28
                            Glad they are helping! Yes, the brick wedges worked well. Just cut off the excess when you're finished - Dave used an angle-grinder. Can't wait to see how you get on.
                            I have more detail described in our thread under Pompeii Oven Construction.
                            Karen
                            • peterlyn
                              • Nov 2008
                              • 79
                              #29
                              Chimney Cap:
                              Formed cap. Poured.
                              Stripped forms and exposed the aggregate.
                              • peterlyn
                                • Nov 2008
                                • 79
                                #30
                                Countertop:
                                Forming and pouring
                                Karen
