Hi All
Thought I would post a few pics of my efforts in preparing the slab for my WFO. the oven will be in the centre and a couple of work areas either side. Under these work areas will be a couple of stainless steel cupboards.
With the slab I have dug a deeper footing and run reo around that. This is also then tied to reo hammered into the natural ground around 400-500mm. Then placed the mesh across and tied everything together. Hope its enough! When I start the wall the intention is to keep going across from the work areas so that it provides more support for the oven and hearth. This will also provide a couple of storage areas. at the rear I thought I might use the other cavity to store more timber - maybe? Concrete delivered tomorrow - too lazy to mix my own.
The oven will eventually be under a verandah and within a pool area.
Thank you all for the info so far that I have read and picked up.
OK one problem - havent worked out how to upload pictures. Will come back soon with pics.
ok i think i have worked out how!
