Re: My 42" Pompeii Oven build, Northeast Ohio
098 - 13th chain complete.
At this point I'm done with the Indispensable Tool.
If there ever was a tool that makes someone look like they know what they're doing, this sure was it.
I wouldn't want to attempt to do this without an IT.
100 - 13th chain complete.
This is a good shot of just how much the bevel changes as each chain goes higher.
Notice the difference between chains 10, 11, 12, & 13.
102 - Wetsaw jig.
The high bevel cut was a later-higher chain.
I removed the angle fence and now held the bricks in place along each line by hand for the correct angle.
One cut is referenced off the front line, the next cut referenced off the back line.
104 - Wetsaw jig.
This half brick shows a 1st cut example referenced off the back line.
105 - Wetsaw jig.
This half brick shows a 2nd cut example referenced off the front line.
109 - Custom keystone.
I now used the compass used to transfer all the points of keystone shape from to 2 clamped half bricks that will become actual keystones.
