42" build in Virginia
  • fabby
    • Jan 2013
    • 111
    #46
    Re: 42" build in Virginia
    I think I will try to make a form and cut some bricks with my grinder and see how that goes. I like the arch deejayoh built with the fancy cuts. Anyone try this using a grinder and diamond wheel?
    • deejayoh
      • Jul 2010
      • 1893
      #47
      You can do it with a diamond wheel. It'll be messy, but it looks like your oven is out in the open, so it won't get all over your house like mine!
      Build your arch support then dry fit the bricks onto the support. Draw the square on the front of the bricks. Cut them with the grinder, and then flip the whole thing around for installation...
      Just remember to leave enough room for your mortar gaps
      • stonecutter
        • Jun 2007
        • 2003
        #48
        I never have but mainly because I like to wet cut firebrick. Even low duty firebrick are pretty hard by brick standards,so make sure you get a blade that can handle it. General purpose are fine, as long as stone is among the approved material listed...these are usually better suited for firebrick. Keep a soft brick handy, and use this to 'sharpen' your wheel...a couple passes are all that is needed to wear the matrix down and expose more diamonds (or tungsten carbide depending on brand) which will really improve cutting performance.
        Old World Stone & Garden
        John Ruskin
        • fabby
          • Jan 2013
          • 111
          #49
          What size mortar gap should I leave at the closest contact of the arch? How about at the top of the arch?
          I was thinking there should not be a gap at the bottom of the archs but butting them together like on the oven? The refractory cement directions recommend no more than a 3/8" inch gap?
          • stonecutter
            • Jun 2007
            • 2003
            #50
            As small as you can without creating tiny brick slivers in your arch.
            John Ruskin
            • fabby
              • Jan 2013
              • 111
              #51
              got it, thanks, I will try to cut some tomorrow.
              • deejayoh
                • Jul 2010
                • 1893
                #52
                Plan on them being larger than you plan... e.g 3/8" is the goal, but be aware that you may need to cut down your keystone when you get there. Just the nature of things in my experience
                • brickie in oz
                  • 3445
                  #53
                  You can make a square opening from brick if it all works and fits, just support it temporally with some timber until it has all set.
                  • fabby
                    • Jan 2013
                    • 111
                    #54
                    brickie, that looks really simple, will that hold up the oven? Are the cuts on angle is what gives it strength?
                    I think I would have to remove some of my dome to make room for a full size brick or my opening would only be 8.5" tall? Could I use a half brick with the same strength?
                    • deejayoh
                      • Jul 2010
                      • 1893
                      #55
                      Hey Brickie - is that the Oz version of sketchup you are using?
                      • fabby
                        • Jan 2013
                        • 111
                        #56
                        Hey don't make fun of brickie's drawing, he draws better than my 8 yr old son
                        • Laurentius
                          • Nov 2010
                          • 923
                          #57
                          Careful boys, tread lightly! You don't know how brickie, gets respect? A brick up side your head.
                          • fabby
                            • Jan 2013
                            • 111
                            #58
                            brickie,..smickie....I'm not afraid
                            aka.....flabbly from australia.
                            • brickie in oz
                              • 3445
                              #59
                              The arch will hold heaps of weight if you bond the brickwork over the top properly, you need some bearing on the underneath bricks, more is better of course.
                              The angle gives it the strength, you could use basically any angle, except 90 degrees.
                              Actually thats not true about the 90 degrees as thats what I did in my oven entry and its still up.
                              Edit:-
                              Here are the next two courses done for you, I assume that you will taking it up as a chimney, or the start of a chimney.
                              Remote bricklaying........gotta love it.....
                              • brickie in oz
                                • 3445
                                #60
                                Its Vinosketch, by the time I get on here Ive done after working all day so a vino or three helps.....
