Re: My Old Kentucky Dome
It's true. A sine-plate like attachment would be a really good accessory to the HF wet saw. I made a fixed sloping attachment I bolted to the table for the many 7 1/2 degree cuts needed for my bricks. You can mark the angle needed with a protractor, and hike the brick up with a block of wood. You'll also get really good at freehand cuts with a little practice - that's how I cut all the complicated shapes needed to transition from the dome to the flue. Just make sure you have the smooth diamond blade rather than the segmented one if you are going to get up close and personal to it.
Originally posted by Dannyboyblue
View Post
