Italian, Australian Oven
Ken H. - Kentucky
42" Pompeii
Cost Spreadsheet ... Picasa Web Album -
Re: Italian, Australian Oven
Way to go guys. That's excellent.
I see that you built the shape for your oven enclosure with wire, but not rebar. How did that work? Also, how are you going to waterproof the oven?
Looking good.
JamesLast edited by james; 10-21-2007, 09:58 PM.Comment
James, when rendering we always use chicken wire (recommended by the field furnace guys also). Has worked for 100's of ovens (over the years).
As for waterproofing do you mean the dome? (im assuming yes) if yes water doesnt penetrate render (a mixture of builders clay, sand and cement). Its like when you cement render a house, water doesnt penetrate the walls. And it wont affect the heating of the oven because of the insulation (the blanket is over 2 inch's thick and in some areas we are doubled up). So the heat from the oven will be absorbed by the bricks/mortar and then the rest is soaked up from the insulation.
To be honest this is a 1st for building 1 but we have seen many been built and have gotten advice from people that have built many for years. The only way to really know if its good or not is too actually use the oven for 2 months and then see.
hopefully everything should be fine
A good example was today, outside today it reached 37 degrees Celcius (98.6 degrees F). But inside the dome it was really cool as the insulation kept the heat out (which would work vica versa, meaning it will keep the cold out when raining).
Lets wait and seeRegards
AdrianComment
Very interseting..well, if he has built many than I'm sure its a proven method. Please try to document the chimney building with photos I'm very interested in seeing this and I'm sure others are as well.http://www.palmisanoconcrete.comComment
Ill see if i can get in there today and snap some photos off.Regards
AdrianComment
Thanks mate, i started curing yesterday (just a real small fire) and to test the chimney (not bad so far).
The wood im using just to start the fire is small sticks (old) and the larger peices we have heaps left over old wood fence pailings (they seem to work well). What im going to do is use thow to fire it up, then buy some apple wood and use it for pizzas (throw it in when the temp has been reached).
Ill try and take some photos of the chimney but i can only do it from the bottom.Regards
AdrianComment
