Mitch's Oven - Forno Bravo Forum: The Wood-Fired Oven Community
Mitch's Oven
  • Mitch's Oven
    Hi, here are a couple of pics of my oven foundation and a cad model of the design.
    Heres the site almost excavated, with a few datums.
    Heres the foundation, I diddnt snap any pics of the mesh/rebar/boxing, this is 0.43 of a cubic metre ~ 8 wheel barrows of hand mixed concrete.
    You can see where I have marked out for the support wall.
    Heres the support wall, with half a course left (they are now done).
    Its pretty hot and sunny so I have stuck up a temporary shade cloth.
    Heres what Im heading towards, its a 1100mm internal diameter Popei style oven, I have made the insulating layer and bricks recessed to my cooking surface is level with my bench height. I havnt fully modelled the door arch or bricks they were really only modelled to figure out how many bricks to order as they are expensive in NZ ($4.50+GST each).
    My next mission is the boxing which is a bit of a mission.
    Ill post some more pics and a cross section of the whole thing when I get the boxing completed.
    Mitch
    oven pics: http://blender.formworks.co.nz/oven/
    Re: Mitch's Oven
    Nice looking work so far Mitch!
    Good to see another kiwi oven go up..
      Re: Mitch's Oven
      Mitch, are you going to stucco the exterior? Looks like you would have no room for framing the exterior upon completion, with insulation layers added into this. The cad details this nicely. Be sure you reenforced the brick wall and to reenforce the slab well.
      Acoma's Tuscan:
        Re: Mitch's Oven
        Yep stucco, a nice igloo hopefully, everything is/will be reenforced reenforcing is the cheapest part
          Boxing
          Well the boxing turned out to be an absolute mission, it took 2 sheets of 1200x2400 9mm plywood and 3 sheets 1200x2400 5mm hardboard, plus about 60 Meters of 100x25 boxing wood and lots of nails screws and bog and beer.
          Having designed such a crazy bench to recess my bricks to be flush with the bench and fit in the space I had made for allot of work, heres a cad model I build so I could lay out the pieces on the sheet to keep the costs down by minimizing wastage.
          And heres the almost finished boxing, I have a bit of sanding left to morrow then I will pour the concrete.
          Hope it doesn't fall over.
            Re: Mitch's Oven
            Very cool ideas. Great pics too. Keep up the awesome work.
            GJBingham
              Re: Mitch's Oven
              so impressive!
              RCLake
              "It's time to go Vertical"
              Oven Thread
                Re: Mitch's Oven
                WOW... Another stunning oven in the works! They just keep getting better and better.
                Ken H. - Kentucky
                42" Pompeii
                  Re: Mitch's Oven
                  I would say that this oven in process is definately moving to a new level. Lobo, you have great ideas. Keep it going.
                  Acoma's Tuscan:
                    Re: Mitch's Oven
                    cistern for water?
                      Re: Mitch's Oven
                      In the background? yes, we call them Water Tanks here in NZ - I have 2 of them
                        Re: Mitch's Oven
                        This is truly impressive!
                        I look forward to following the progress of your oven. Having just completed mine I'm more than impressed with the array of foods we have been able to cook in it. You will be thanking the day you made the decision to build a
                        WFO.
                          Re: Mitch's Oven
                          Finally poured the bench with some help, more concrete than the foundation in the bench 0.46 of a cubic meter.
                          Heres some of the Reinforcing:
                          Screeded Concrete:
                          And polished concrete, kept wet so it wont crack hopefully:
                          Insulation layer next before the real fun begins.
                            Re: Mitch's Oven
                            WOW!!!
                            Jim
                              Re: Mitch's Oven
                              Originally posted by jcg31 View Post
                              WOW!!!
                              I was thinking something very similar. Keeps getting more and more interesting!
                              Ken H. - Kentucky
                              42" Pompeii
