Brick oven completed
  • Brick oven completed
    I built this 2 years ago and have many a good meal , pizza cooks approx 1 minute on up depending on temperature , used ceramic insulation around dome and undernearth hearth , wish I'd put a temp gauge on but never got round to it , top is thin copper cut into shingles , I have a Waterjet machine so it helps , most of my research was done on this website so I figured I would share additionally the tops are poured concrete with black dye , the concrete did crack a little around BBQ to me it adds to aging , decorative tile is slate from Home Depot and yes I cut all those small squares , but was worth it , hope you enjoy .
    Terrazzo,
    That is a fine! looking oven. The cut tile, the curved enclosure, the conical roof, the copper singles (all together), make for a "one of a kind" oven . And, I'm jealous of all of the extra space that you have in the area. Beautiful Job!
    Also: Can I ask what is in the entry?
      Below the oven is purely decorative and a place to store wood , above was a poured concrete slab with ceramic insulatin board atop that was fire brick , a dome oven made out of fire brick also encapsulated with ceramic insulation thanks
        WOW that is a work of art deffo the best I have seen to date .Loving the copper shingles and the curved tower you have encapsulated the oven in. Now I have seen the concrete tops it has me thinking could I do that ?. well we will see as I was going to use tiles.
