Just a thought... what about putting a layer of tile backer boards on top of the concrete? In a 6mm sheet it would have no impact on the working height but would lift the boards clear of the concrete for both rising damp and seepage. They're supposed to be waterproof for use in wet rooms and such...
New build - 1.2M dome
Surprised how few places stock 3/8 UNC stud and connectors here (or even good old whitworth)... anyway, connectors arrived today so I could put my IT together. Once again I have borrowed an idea I saw somewhere on the forum - using a tripod ball joint - but can't remember where; thanks whoever it was
My bracket isn't at right angles, because I have a pile of arch bricks for the dome. The tripod ball joint could be bigger, but I was trying to minimise the added height above the floor - it's all metal and seems to work ok, and for a couple of quid I'm not complaining.
I have a quick release clamp thing to go with it too, if needed.1 PhotoComment
Great looking IT! In your case (with the arch bricks) that should do just fine. Like 99.9 % of ITs there will be some difference between the horizontal length and the vertical length. As long as you are aware of that and take that into consideration when you mount it at or probably below the finished floor level, all is good
Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build👍 1Comment
Thanks. At the moment I am thinking of fixing it to some 1/2" ply that I've cut to cover the hearth bricks, putting the pivot point an inch or so above the hearth. To compensate I'll cut a course of 'half soldiers' at the right height and angle to put me back onto a hemisphere with the IT. If that makes sense.Comment
I have a question about setting the soldier course. Although my hearth was flat and level the calsil varied somewhat in thickness so, as I learnt here, I levelled with a mixture of sand and fireclay. I'm about half way through that job.
I understand that the soldier course is not normally mortared down, but then it will be rather wonky sitting straight on those boards, especially along the joints between sheets. What should I do? I'm thinking I will have to apply at least a thin bed to create a flat and level basis for the subsequent courses?Comment
Jonv, have you considered pulling out your "center" floor brick and using the wooden brick trick? I don't know if Gulf invented it, but I copied his
. You adjust the thickness of the wood to put your pivot point right at the floor level. If you do that you can have the hemisphere without having to do any adjustment.
1 PhotoMy build thread
https://community.fornobravo.com/for...h-corner-buildComment
If you do as you describe, it will be a perfect hemisphere in a horizontal plain from the top of your soldier course up. There will still be some difference in the ID of the dome. From the center point to the walls of the dome and from the finished floor height to the apex of the dome will be different. No biggie, your oven will cook just fine.
I don't think that it will matter that much if you are mortaring to the CalSil. There is enough residual dust on top of that stuff to prevent a solid bond. Imo you can use what ever mortar you need to start the dome wall level. It might, if you were setting the dome on top of the floor brick. But, if you are setting your dome outside the floor use some cardboard to set the distance between the floor and the dome. It will keep the mortar from filling in that expansion joint.I understand that the soldier course is not normally mortared down, but then it will be rather wonky sitting straight on those boards, especially along the joints between sheets. What should I do? I'm thinking I will have to apply at least a thin bed to create a flat and level basis for the subsequent courses?
As for as soldier courses go: You don't need a soldier course. If you are after vertical height before starting the curve, you can do the same thing by laying the first row (or two or three) with the bricks in the same orientation as the rest of the courses. You will have a stronger bond if you do that way.
Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
I probably did come up with the wooden brick. But, I was too green to think of lowering it below grade to accomodate for the difference in the pivot for the IT as you did. I actually started out with a plywood floor covering the floor brick and mounting it to that. But, it was as Jonv calls "wonky" so I came up with the wooden brickJonv, have you considered pulling out your "center" floor brick and using the wooden brick trick? I don't know if Gulf invented it, but I copied his
Impressed that you figured it out in practice Gulf, I didn't figure it out until I built the spreadsheet. Took me lots of maths...Comment
Thanks both for your thoughts on that. The wooden brick idea is a great one, but when I got hold of some 12" x 12" x 3" blocks, which I hope will make for a great hearth, that idea went out of the window. They are really heavy and I didn't fancy trying to drop one in at the end without much of a chance of getting the level right.
You're quite right, my oven with be a little taller inside than the radius of the dome, but over that size I figure it will be ok and saves me having to do any adjustment as the dome progresses. I am trying to minise that extra height though - using 12mm ply instead of the usual 18 and using a mini tripod ball joint instead of a proper sized one.
I didn't think about the strength of the bond being better without a soldier coarse
Having seen them used on so many builds it didn't occur to me that there were disadvantages. How much difference do you think it makes?
I need to think about this a bit more. I only have a few flat bricks, and they are needed for the start of the arches and the vent area. The rest are all arch bricks, which makes it a bit tricky to lay a vertical section to bring the level above the floor...Comment
Finished setting out the hearth today. Like others, I used a mix of sand and fireclay to deal with my somewhat variable calsil layer. I did try to do it dry, but found it much easier to mix it to a thick paste and apply to the blocks first with a notched trowel. I was surprised just how much fiddling was needed to get it more or less flat and there's not a lot of working time before the calsil has sucked the moisture from the paste.
Following earlier feedback, I dealt with the possible problem of rising damp with three thick layers of waterproof paint, hence the now black slab. I wanted to raise the calsil off the base a little, so put down a layer of 6mm tile backer boards, which I treated with three coats of sealer, although the third coat seemed to evaporate more than soak in. With that, and the two holes drilled through the boards and slab, I think the moisture issue has been dealt with
1 PhotoComment
The fiddling has just begun, and there is a lot more to come. I probably should have fiddled a little more, but now I am close to plugging the dome. Good luck.👍 1Comment
