New build - 1.2M dome
  • jonv
    • May 2015
    • 255
    #76
    I finally have the tapered arch in place
    It was a bit tricky but I'm happy enough with how it turned out. Hopefully things will progress a big more quickly now.
    • deejayoh
      • Jul 2010
      • 1893
      #77
      That's impressive work. Looking forward to seeing the rest of the dome go up!
      • SableSprings
        Moderator
        • May 2009
        • 1310
        #78
        That's awesome Jonv! Really interesting seeing the complete arch with angles prepared for the dome incorporation. I don't think I would have been able to dream of doing that back when I did my oven...that's why I used the square/angle iron entry method . If I build another oven, I'll certainly come back to this build and use all the tips you got from other forum members to create this beauty! It's fantastic what's being created with input from the forum. Thanks to Utahbeehiver, Gulf, JRPizza, MrChipster, Deejayoh, David S, CobblerDave, and many, many others for their continued interest in seeing EVERYONE succeed here!
        Roseburg, Oregon
        • jonv
          • May 2015
          • 255
          #79
          Thanks both! It really is great to have the collective experiences of so many previous builds to go on. Much easier than the pioneering stuff other folk have done
            Great job! Jonv.
            That will be a set of pics for lots of future oven builders to reference. A picture is worth a thousand words .
              • 5260
              #81
              Top notch, done nicely.
              • jonv
                • May 2015
                • 255
                #82
                Thanks for the encouraging comments folks
                First two courses are done... twelve more to go.
                • underpendle
                  • Sep 2016
                  • 42
                  #83
                  Looking good.
                  S
                  • jonv
                    • May 2015
                    • 255
                    #84
                    This might take a while... two more courses done.
                    • deejayoh
                      • Jul 2010
                      • 1893
                      #85
                      Looking good! It goes faster once you are over the arch. Smaller circumference, and the cuts are all the same. Tricky part is gravity becomes more of a factor
                      • jonv
                        • May 2015
                        • 255
                        #86
                        That's true, although it is going to be much more tricky to work on when I get that high up. It looks so much bigger than it did on paper!
                        • deejayoh
                          • Jul 2010
                          • 1893
                          #87
                          Bigger, yes - I can see that! you could live in that thing
                          Gravity can make it tricky, but I was pleasantly surprised at how well the homebrew holds the bricks, if you mix the consistency right. I found I never had to use any sort of support beyond a couple minutes with the IT.
                          • jonv
                            • May 2015
                            • 255
                            #88
                            I'm dreaming of jamming a whole pig in it sometime
                            I am expecting gravity to become a bit of a factor on the next course - I already noticed a couple of bricks drifting forwards slightly and needing to be held in place for a few seconds before the mortar grabbed hold. I'm using an aluminate cement rather than the homebrew. I suspect that it is a bit more tricky to use but it does set up much more quickly.
                              • 5260
                              #89
                              One of the more nicer builds I have seen in a while, very nice brick work. Patience is a virtue.
                              • jonv
                                • May 2015
                                • 255
                                #90
                                Thanks! Luckily, patience I have... the other skills I'm still learning
