I did bring in a truck. It took 1.5 yards for the top. More then I wanted to mix by hand. Plus I wanted a color in it. I figure the only way to get a consistent color through out was to have it all blended at once. I wanted the color of Oyster. I was told that it dries and works up a shade lighter then the chart. I ordered the color Orchid, in hopes that it will dry and work up close to Oyster. The photos are a little deceiving. It is not smooth at all. It is very rough. But it is very level. Will do a test grind today. It will get polished up like granite. I have various color gravel and stones and trap rock in the mix. All of these colors will be present after the grind and the color of Oyster will be the base or background color to the exposed polished aggregates.
Wow, that sounds like it's going to be really nice. Will you do any acid staining on it?
Doing the base and foundation for mine nearly killed me - we had ~3 tonnes of concrete in total, done over 2 weekends. It's really on the limit of what 2 people can do themselves (or is for me). I think someone on the forum poured their hearth slab mixing all the concrete by hand!
It looks wonderful. Be sure to keep them covered up while you work on the oven! That'll get a bit sloppy even when you're careful. And the bricks can be quite abrasive.
