1.2M Oven w/BBQ & Tandoor
  • Irish Chippy
    Originally posted by david s
    I think you will need to research a little more. Crushed limestone is not a cementious material, it needs to be calcined. The process is to heat the crushed limestone to around 900 C, it then acts like cement.
    https://www.lowtechmagazine.com/2013/09/lime-kilns.html
    Wow David. Thank you
    The anapog I have is not anything like limestone we get in Ireland
    It is just like chalk, and the locals say this is used for make paledada
    As I said in the last post, this stuff breaks in your hand
    Best I do bit of testing then
    Lime burning is a now-forgotten industry that sustained many agrarian communities before energy became cheap.
  • Irish Chippy
    The hydrated lime is a cementious material and capable of withstanding higher temperatures than portland cement.(around 500C as opposed to around 300C). This is its primary function in the home-brew mix. If you replace it with clay which is quite refractory it is not a cementious material although it will set quite hard as in a cob oven. It is really only an extremely fine aggregate. Also the higher proportion of clay in the mix leads to more shrinkage (cracking).
    Apologies for not getting back to you all sooner. With budget, building new house, ruptured gallbladder amongst the reasons
    Of course the issue of hydrated lime was a stumbler.
    Then after a bit of research, I asked around and of course many of the old Spanish buildings used adobe blocks and lime mortar for joints and render
    This render/plaster is called Paledada and is made from anapog which translates to limestone.
    Armed with this word, anapog, I found out there was a deposit of it 400 metres from my house on the mountain side. The owner owner of the land is a friend, so he said I could take what I need.
    It will take a few days to grind it down to powder. It breaks in pieces your hand, but working it to a powder takes more effort.
    Now, back to this homebrew. I have the lime. I have potters clay, I have sand. I have cement
    Recipe suggestions would be much appreciated.
    Budget remains the same:
    • Perlite 100 L .......... $25.00
    • Shipping ................ $21.50
    • 60 hollow blocks ... $19.00
    • 4 bags Portland .... $18.00
    • 300 bricks ............. $60.00
    • 10 bags portland ... $45.00
    • Perlite 200 L ...........$50.00
    • Shipping ............... $43.00
    • Portland ................ $4.50
    Running total : ................. $286.00
    Originally posted by Irish Chippy
    Thank you Russell. Maybe I read it from one of your older posts
    Correction 5:1 for under floor 8-10:1 for over the dome
    No, it is the air in the bottles that does the insulating. Use empty ones, don’t waste the wine.
  • Monilee
    Can I use full glass wine or liquor bottles in the floor under the vermiculite as extra insulation?? I just now got the bags or vermiculite and can finally start my build.
    Thanks.
  • Irish Chippy
    Thank you guys.
    I have used sand cement lime mix years ago. But the lime was mostly replaced with plasticiser (we used to call mortariser) in the 80's. We even used dish washing liquid to make the mortar 'fatty' or "puffy' and easier to use.
    So how about using the clay I got from the pottery instead of sand?
    It is the very same stuff that is used to make the red bricks that I am using
    Great point, keep me on track, I was looking more at workability not refractory.............
    Russell,
    Although lime can be replaced with substitutes in standard mortar, I'm not so sure that it can be replaced in a refractory mortar. I was involved in a discussion with Tscarborough several years ago about type-N masonry mortar. (It would be great if he would join in on this conversation) The original formula for Type-N masonry cement was 50/50 lime and portland cement. Most all major manufacturers of masonry cement have replaced the lime with crushed limestone and other additives. There are still a few small companies here in the US who make it by the original formula. If there is a manufacturer in the Philippines who makes it by the original formula, it can be used to make home brew.
    There are some mortar plasticizers than can be a lime substitute. A Google search shows several.
  • Irish Chippy
    Am wondering about the mortar mix. Cannot get lime. I have a few bags of potters clay (the same stuff they use to make the bricks.
    Any Ideas?
  • Irish Chippy
    This perlite has eaten a big hole in my budget. The shipping is the killer
  • Irish Chippy
    The perlite base is now complete. I used 300 litres of perlite in the mix with about 60 litres of cement, and that has taken me to about 10mm of the top.
  • Irish Chippy
    Just ordered the Tandoor. Well I drew the shape and asked them to make it. It is 600mm dia on bottom, 450mm dia on top, and it is 700mm high. It will also have a lid.
    Below is a couple of photos of our local pottery ...
