Re: Hansen Horno
Hi Darin,
I am ready to mount the chimney anchor plate. I plan on following your technique with tapcon screws. What size did you use? I assume the insulation is to allow for expansion and prevent the hot plate from fracturing the brick base. How is it holding up? Would the screws heat up and potentially fracturing the brick chimney base? My other option is to use the technique Dino did. Looking for your advise.
Thanks,
Dan
Hi Darin,
Thanks,
Dan
