Re: The Morgan's WFO build
We worked all weekend to "catch-up" a little on our project. We decided to go ahead and put a center support column beneath the hearth structural slab. We simply stacked some 8x8 concrete blocks and tied the top end into the forms and inserted two peices of rebar. The inside of the blocks were filled with concrete during the pour of the structural slab.
The form for the structural slab was pretty straight-forward, but the form for the 15 foot bench took all day Saturday to build and re-inforce. Here's a photo of the forms just prior to the pour...
And here's a photo shortly after the pour...
It's nice to have all the "heavy" work behind us. Next, we are going to route some drain pipe and take care of parts of our patio. The next stage on the oven will be the insulation slab and the oven dome.
The Morgan's
The Morgan's
The re-installation of the hearth was a major improvement. There were still a few edges that were high and I wanted to fix them. I read on here where some people sand them down, and just the other night I read a comment where some asked "Can you imagine rubbing bricks together to obtain a good fit?" - referring to an old-world way that craftsmen would work. I chose a brick with a chipped corner, and layed it on the hearth and began rubbing (grinding) the hearth by hand. It actually works very well! I found if the bricks are moist and the dust (mud) cleaned-off from time to time, it actually goes pretty fast. I spent about 10 minutes doing this and will probably do about another 10 minutes before the door arch goes up. The hearth is really smooth and slick!
