Re: 36" in Seattle
We wanted our vertical rebar to be set into the slab. 'Not sure if this was necassary, but we mapped-out where the rebar should go with string when we poured and screeded our slab. I marked the tops of the form to indicate where to place a screw, and after the screeding, we put sheet-rock screws into the forms and then loomed string from screw to screw in a fashion that created a pre-planned grid of intersecting strings over the top of the concrete. The intersections of the strings over the wet cement indicated where to place the rebar. I just stuck them (easily) into the concrete by hand.
Granted, the concrete was only 4" thick, but was effortless. I think you could insert them with no more help than a hammer for the last little bit. If you worry about the media deflecting the rebar, grinding a point on the end of the rebar would help. I think it would be pretty easy to insert them. Try it with one and see how it goes.
Ken
Ken
() Great stuff, very beginner friendly and adds structural strength to your block base.. You can do both the inside and outside with it,, You can also add Acrylic Fortifier for water proofing and color as well...
bearing in mind that I really dislike rectangular "buildings" with conventional gabled roofs.
