Re: Wrong dimensions - Help!!
So far it has been suggested that we use penetrating sealer, and also this option of the bituthane type. Sealer may not last over time; certainly the bituthane would in normal conditions. But what about when the oven burns hot? We realize because of the brick floor layer over it and an airspace (not to mention the metal plate beneath brick) that heat coming down won't be at it's extreme, but certainly there is going to be heat. We already know this because the floor rapidly and continuously drained heat out of the oven. That means that some significant heat will hit the bituthane below across the airspace. Any chance we'd end up with a slight signature pizza flavor from vapors?
Pros and cons: That was con. Here's pro. Since we are demo-ing all the way down, the metal floor support is solid, not in pieces. So the only place for vapors to go is sideways, into the walls. Heat does push out, but gasses expand to fill the size of their container which means if there are any vapors from this material, I want to be totally sure our food doesn't taste like someone is tarring the roof next door. This kind of puts me back to favoring a penetrating sealer that is dry cured once it is dry. Last question on this: Metal fabricator said as long as we are using the firebrick (of course, that's the floor) over his metal, 3/8 inch is plenty without worry of warping it. Steel is a hell of a vapor barrier, except for condensation from cold wet underneath. Ah, did I just reinforce the need for sealing that slab... Or does it really matter what happens below the steel as long as there *is* an air space beneath it, wet, dry, whatever?
