Hi all,
i have just attached a steel frame to my trailer,
the top of the frame will support the oven,below that will be an area for wood storage.I have decided to do a 75mm\3 inch thick fire hearth made from a aluminate cement hearth recipe,below that will be a 100mm\4 inch perlite cement insulation 10 to 1 brew.
so what do I put on this frame to support the above,I dont want to add more weight by adding another layer of concrete as a base,so was thinking of using 20 mm treated plywood.
so there will be a total off 175mm\7 inches of fire hearth and insulation layer,enough to keep the heat away from the wood i,m hoping.
another puzzle for me
do i place the fire dome directly onto the perlite base then trowel in the fire hearth inside the dome(leaving a gap around the edge) .
i know the perlite will be brittle so cant see how this would work,so would i have to do 2 layers of fire base,one to support dome and second to go inside dome....pheeew! would be great to get this sorted as i have to do it tomorrow, cheers all
