1 inch ceramic fiber board floor insulation
  • 1 inch ceramic fiber board floor insulation
    Hi,
    Again questions about floor insulation
    I am currently building my igloo stove using a 1 inch thick ceramic fiber board above my concrete slab below my 3 inches fire bricks floor.
    I will put a 3 inches ceramic fiber blanket on top of the 4.5 inches fire brick dome for insulation.
    Do you think that 1 inch ceramic fiber board is enough for the floor?
    Also the edge of my concrete slab is touching the bricks of the entrance door in the front.
    Should I leave a gap somehow?
    These two photos are some days old. I now have only two rows of bricks to put and I will be done with the dome. I can not just move the bricks around easily anymore. I would have to remove the entire floor without damaging my dome to add anything under the floor.
    Thanks in advance for your answers.
    cheers
    Thomas
    Re: 1 inch ceramic fiber board floor insulation
    Thomas - if you have your dome nearly completed then it is too late to add any insulation. You should do ok with what you have.
    You can add a thermal break between your inner arch and the entry gallery. It does not need to be very wide to stop the heat transfer and is worth the doing. A quick search of the threads will reveal plenty about that.
    I am curious about the lip on the outside of your base slab. It looks like a potential water reservoir. You will need to ensure that water can not enter and be held there otherwise you could end up with a very wet oven and insulation under it.
    All the best with your build.
    Cheers ......... Steve
      Hi,
      Thanks for your answer.
      The final floor around the oven will be leveled with the lip.
      I am planning to put terra cotta tiles above and around the oven.
      I will send photos once it is done.
      cheers
      Thomas
