Duane's 42" Build
    Originally posted by Hamilton View Post
    I will give it a try.
    Can somebody remind me of the formula for the render coating and the thickness?
    I have 3" of insulation so I think I can go straight the the hard shell.
    You can buy a premixed commercial render that has a degree of waterproofing, or make your own brew. A high proportion of lime give the layer a degree of elasticity. 4:1:1 sand, Portland cement and lime is pretty good and if you add 50/50 water and an acrylic fortifier, you’ll also get some partial waterproofing. Once perfectly dry an elastomeric acrylic coating can be applied to fully waterproof the surface if desired, but the outer shell then is not breathable. The addition of random fibres to the render mix makes mesh reinforcing unnecessary and saves lots of time. I usually apply this outer render in one go to around 12-15mm thick, basically to save time, but the recommendation is not to exceed 10mm and to be done in 2 layers. Use a wet sponge to smooth out tooling marks.
  • Hamilton
    Hello,
    The bricks were laid on a 50/50 mix of sand and clay.
  • bencuch
    Hi Hamilton,
    You have created a really beautiful building.
    The floor bricks were glued to refractory concrete or laid freely on a mixture of brick and clay
  • Hamilton
    I have seen some builders scoring or cross-hatching mating surfaces of bricks with an angle grinder and diamond wheel to reduce slippage and increase the mortar grab. May work here.
  • Hamilton
    Hey all.
    I have attached a few photos.
    One of the sealer/adhesive used to secure the chimney pipe base to the firebrick, rated at a much higher temp than what we are using. It is rock solid.
    My chimney cap made of the refractory castable separated from the mortar. I already had concerns about that area due to the temps at the time and the mortar did not have a chance to cure as a opposed to drying out. Needs some suggestions at this point on how to secure the cap to the chimney? The dome will be intersecting the backside of the refractory chimney cap due to poor planning. Click image for larger version
ID:	448768 Click image for larger version
ID:	448769 Click image for larger version
  • MarkJerling
    Looking great. Well done!
  • Hamilton
    Good morning. Insulated the dome with 3" of blanket from our host at Forno Bravo and put the oven through five twelve hour days of drying fires. I ended up removing the perlcrete mixture around the base of the dome and used the blanket instead. It took me a minute but I found a crack in the dome that I was hoping to get lucky and avoid. Had a few of our kids, grandkids and one of the neighbors over for pizza yesterday afternoon. The best pizzas!!! Click image for larger version
ID:	448659 Click image for larger version
ID:	448658 Click image for larger version
ID:	448660 Click image for larger version
ID:	448661 Click image for larger version
  • Hamilton
    It is a shame!
    It is really a shame that all the pretty dome brick work will be covered by insulation. You are on the home stretch.
  • Hamilton
    Hey guys, hope everybody is doing well!
    I haven't had much time to spend with the oven lately.
    Doing what I can in these couple of days off.
    Attached are a few photos of the latest progress.
    Ready for the insulation and render know I believe.
    I will be cooking out of this oven before the end of the year. Click image for larger version
ID:	447731 Click image for larger version
ID:	447732 Click image for larger version
ID:	447733 Click image for larger version
ID:	447734 Click image for larger version
    The highest rated silicone I could find is Permatex Ultra Copper, which I use in my builds. It is ok provided flames are not allowed up the flue pipe. After about ten years use the stuff remained intact and elastic until my wife killed it when firing up the oven and allowing flames into the flue pipe. It killed the silicon, so I had to redo it. No big dramas, but I sacked her from firing the oven.
    There are other non silicone solutions, but all that I tried went hard and didn’t remain elastic meaning they didn’t seal against material that is expanding and contracting frequently.
    If using it under an anchor plate I think that will be too hot for silicone. The seal on my build is quite a bit higher up and therefore cooler. In that position it wouldn’t matter if it goes hard because it will presumably be covered in insulation.
  • Pizzarotic
    Any fireplace or flue supplier should have high temp product's. Most pure silicones are rated for 400-600⁰f but can handle a lot higher temps. Lavalock ​have a 1000⁰ tape and Vitcas do a 1800⁰ sealant.
  • Hamilton
    Can anybody recommend a high temp adhesive/silicone to attach the chimney pipe anchor plate to the fire brick?
  • Hamilton
    One more thing.
    Look at all these excess cuts and "practice cuts".
