ciao amici
  • forno di Lucca
    • Oct 2010
    • 23
    ciao amici
    I went to Italy with my father about 15 years ago and it was there that I remember seeing my first 'forno a legna' or WFO....it was in the kitchen of my dad's cousin and it was a marvel to look at... although they had a modern oven and stove, the WFO was what they used most.....the smells and aroma eminating from that kitchen....and the fresh cooked bread...out of this world!!!!!!!
    I think that was the moment!!!!
    It has taken many years and many things have changed but I have come to the point where I want to experience it again....and again......and again!!!!!!!
    and so like many of you my journey begins.......
  • fxpose
    • Jul 2009
    • 942
    Re: ciao amici
    This is where it begins...
    George
    My 34" WFO build
    • efleifel
      • Jul 2008
      • 88
      Re: ciao amici
      This is why I built mine, and building another one now. I remember as a kid, my mom used to ask me to fire up the clay/brick oven outside behind the kitchen, almost every day, and she used that oven not only for bread, but also for cooking meet and vegetables. So, When I had the opportunity I decided to build one.
      You will enjoy this experience, please post photos whenever you can.
      a piu tardi
      Eddie
      My Web site
      • forno di Lucca
        • Oct 2010
        • 23
        Re: ciao amici
        thanks Eddie and George
        this truly is the beginning....I am just trying to source all the material first with a projected construction date of May 2011(yeah it takes a while for the ground to thaw up here...LOL) . I have decided on the design and have already began to stockpile some concrete block for the foundation. Thanks to Jurrasicjockey for providing me with some firebrick and some insight into construction. I can't wait ....the anticipation is killing me!!
        • tdibratt
          • 112
          Re: ciao amici
          For materials check these out:
          1. Firebrick, masonary products, clay flue pipe, brick sand, sand/gravel mix, vermiculite -> Bernardi Building Supply
          2. Insulating hearth fibreboard and insulating blanket - Alphatherm Inc (Ask for Elvis as he has helped many a WFO builder and can get you the proper products. I used KFAC-19 under my hearth)
          Good Luck
          Check out my build at:
          http://www.fornobravo.com/forum/f8/t...uild-4678.html
          • forno di Lucca
            • Oct 2010
            • 23
            Re: ciao amici
            Hey Tony
            thanks for the information.....I will get in contact with Bernardi for the material.....I actually found some material at MASONS MASONRY.....they carry the fireproof mortar and firebrick as well.
            • forno di Lucca
              • Oct 2010
              • 23
              Re: ciao amici
              hEY TONY
              Just got off the phone with Bernardi and it does pay to shop around....thanks for the tip....
              • tdibratt
                • 112
                Re: ciao amici
                Yup. I have bought from Mason's before as well. But this past summer my dad decided to build an oven and so I did some digging and Bernardi's prices were good. Still went to Mason's for the exterior bricks for the facade.
                Good luck
                • tdibratt
                  • 112
                  Re: ciao amici
                  Oh and I forgot. If you are making your own homebrew and need fireclay, Check out Tuckers Pottery.
                  Home
                  I used Hawthorne Fireclay.
                  Regards
                  Edit/Delete Message
                  • forno di Lucca
                    • Oct 2010
                    • 23
                    Re: ciao amici
                    is it better to go with the homebrew mixture or the pre-mixed mortar for alphatherm???
                    • tdibratt
                      • 112
                      Re: ciao amici
                      I've used both. Actually come to think of it, I used the pre-mixed from alphatherm and buttered the inside edge of the bricks for the dome and then used homebrew to fill in the gaps in the back side because those gaps are wider and the pre-mix is pretty expensive. Worked OK for me. Just make sure you get the air dried pre-mix not the heat set kind. If memory serves me the air dried stuff is not water soluable when dry. Not that you'd be getting any water in the oven when done, but more peace of mind.
