Hello from Japan
  • samuraistu
    • Feb 2011
    • 7
    Hello from Japan
    Hi all,
    After years of being not happy with my home oven pizza results I finally turned to the internet to find out why and luckily stumbled upon fornobravo.com. Since then I have downloaded the free plans and started work on my own 36" oven but now I need some assistance.
    The only blocks I could find in Japan were 39cmx19cmx10cm so they are not so wide and after building I'm a little worried that the wall will not be strong enough to support the concrete hearth....Anybody care to share their opinion?
    Stu
    Here is the link to my gallery
  • azpizzanut
    • Aug 2010
    • 397
    Re: Hello from Japan
    Hello Sam,
    Do you have regular size firebricks for the oven? There are professional brick layers and concrete/cement experts on this forum who will get you cooking without too much difficulty.
    Cheers,
    Bob
    • azpizzanut
      • Aug 2010
      • 397
      Sam,
      Your bricks are ok. They are actually about right for a base. Please send photos of your construction plans and progress.
      Cheers,
      Bob
      • Laurentius
        • Nov 2010
        • 923
        Hi Samuraistu,
        The blocks used here are fine. The Japanese building code requires that the blocks are mortared and Re-bared, the block are designed with channels for the Re-bar. I completed my oven a few months ago, you can view it under(Pompeii in Japan). You can also find the large blocks at your local Komeri home center.
