Castable questions
  • Castable questions
    Hi Gang
    I am just starting to look into the idea of buying/building an outdoor oven.
    I have a whole list of questions and even a few likely off the wall ideas. Please let me boor you with just a few in this post.
    1. I am in Wisconsin and wonder if it is possible to use an oven in the winter with -10F temps as often as 40F for 6 months of the year.
    2. I have a crazy idea to form an oven from a casting of the inside of my wheelbarrow. It seems about the right size and shape for at least 1 16" pizza and a bit of a fire. A separate brick opening might be nice looking and functional if a chimney is needed, and a door seems preferred also. Can it be done? I haven't ever touched refractible cement mixtures, but have done pottery firing as an art teacher many times.
    For any information any of you might be willing to share.
    John
    Merrill, WI
    Re: Castable questions
    I think your idea has merit. be sure to paint the barrow with a release agent. I use motor oil, kerosene 50/50. You could cast in the door ensuring the 63% ratio of door height to internal oven height. The barrow form will give you a good release. I am also a pottery art teacher and much of the information and learning crosses over. Presume you have a fair amount of experience making castings. Suggest you make the walls 2" thick (check with a marked satay stick) and add stainless steel needles (at least 2% by weight) to the mix. don't mix more than one 50lb bag at a time it goes off really fast. Make the flue gallery separately to take the flue pipe.
      Thinking outside the square, cool.
      We need pics of the progress.
      My Build.
      Books.
        Hi Gang
        I am still in research phase, but have made some progress.
        I am looking at a product from Empire Refractories for casting my own oven shell. It's called KS-4V Plus and they have it for $41.47 per 55 LB bag. I believe it is an ANH/Harbison Walker product and from the MSDS here is the main ingredients...
        Chemical characterization
        ? Description: Mixture of the substances listed below with nonhazardous additions.
        ? Components:
        1302-93-8 alumina silicate 30-60%
        14464-46-1 crystalline silica (cristobalite) 20-30%
        1344-28-1 non-fibrous alumina 10-20%
        12042-68-1 calcium aluminate 3.3/2A, 3.8/3 10-20%
        14808-60-7 crystalline silica (quartz) 0.5-0.9%
        organic fibers 0.1-0.5%
        Two different refractory supply places that I talked to thought this would be an appropriate material to use. I was wondering if anyone out there has used this formula refractory cement for their WFO builds.
        Thanks for any advise.
        John in Merrill
          Oh David
          Should I take the meat off the satay stick before or after I measure?
          And how about using this composite lawn edging for stackable side forms and arched entrance?
          John in Merrill
            Originally posted by jgestner View Post
            Oh David
            John in Merrill
            1. Always eat first, accompanied with alcohol.
            2. I like the composite lawn edging idea. These sorts of oily plastics resist things sticking to them, so I think it will be a good material, but only for straight walls, you'll need something else for the compound curves.
              Hi Gang
              I have purchased some materials to start experimenting with cast WFO techniques.
              I have a full bag of Vesuvius dense refractory cement, ($25.00) that claims to be 50% ALumina/ Al2O3 and has a temp capability to 2900F. The full data sheet is here Technical Specification Datasheet Level 3
              The oven guy that sold me that also sold me 1/2 bag of Mt. Savage Insulating Refractory cement for $10.00. I believe it's one of these, Insulating Castables but haven't had enough time to look too hard at the bag yet.
              I hope to use the composite lawn edging like this http://www.mastermark.com/product_de...ct_group_id=74 as inner and outer forms for side walls and arched oven opening sections.
              Haven't had time yet to start experimenting, but if any of you see some significant problems with these materials, please get back to me.
              John in Merrill
                Hello jgestner,
                I'm sure you've given a lot of thought to your design and I wish you the best of luck. One thing I'd like to recommend is that you do your best to calculate the amount of refractory concrete you will need. I did some casting lately and ran short. Lucky for me that I was still able to use the casting for its intended purpose.
                A vibratory sander held next to the form will help remove air bubbles and voids. I used a hammer drill with a bolt in the chuck to the same effect on 2" x 4" forms for concrete slabs.
                You might consider either vermicrete insulation or ceramic fiber blanket on the outside of your oven. Insulating castable refractory is fine too, except it gets expensive. (I used a product called Kaolite). It also adds to the moisture "load" of the oven, as does vermicrete. Just more moisture to drive off with curing fires.
                It is easy to post photos of your progress. I'd like to see how your project develops.
                Cheers,
                Bob
                Here is the link to my oven number 1 construction photos!
                Here is the link to my oven number 2 construction photos!
                  Your materials sound ok. Don't forget to use some release agent. Don't mix up too much at a time. Use stainless steel fibres (2% by weight). The stuff is quite temp. dependant, add chilled water if it's hot weather and it doesn't need to be cured for a week, just cover it for 24 hrs and you can remove it from the mould and it's ready.Wash out your barrow or mixer before mixing more material to avoid accelerating the new batch going off.
                    Hey John,
                    Are you still intending to use the wheelbarrow as a mould? I really like this idea- you could be starting a revolution. You will need to form a door and make sure it is around 63% of the height of the oven interior. Once you have created the casting you can build a form in front of the door. Damp sand is the easiest, then cast over the sand with the castable to form your flue gallery (1" thick should be sufficient for this). For your barrow dome I think a 5" flue should be sufficient.
                      Hi David
                      While I still look at that wheelbarrow a few times a day, I kind of like the idea of building a few stackable modular rings with the composite lawn edging as I showed in post #5 above. In post #7 above I have a direct link to the company making the Terrace Board composite edging product that is readily available here. On that page they also show basically the same material sold specifically for forming concrete.
                      I think a few inner/outer rings of composite to cast sidewalls would be almost easier than the full wheelbarrow mold cast I was contemplating earlier. I have a feeling though that both will work as well as many other home built methods.
                      The castable dense alumina product I am looking at is only $25.00 for 55 lb/ about 25 KG. I think with a fairly low dome (likely sand dome cast) , I might only need 6 bags.
                      I haven't decided on base yet for insulating and supporting, but I have come to like the idea of an aluminum or steel stud housing with cement board walls and tin roof around the oven. I can not see how vermiculite or perlite just poured into that structure to fill it would be any poorer than an insulating castable material or insulating fiber.
                      I am no expert but I am at a price threshold that will allow me to totally fail with this concept with no tears, especially if I build it away from any other valuable structures.
                      As usual comments for and against are welcome.
                      John in Merrill
                        Good luck. Keep posting, but accompanied with photos.
                        Dave
