Propane (gas) Pompeii won't get up to correct temperature
  • ss0357
    • 1
    I just completed a Pompeii oven with 42" floor. I have hooked up propane to it and have a great flame. I spent a week bringing it up to temperatures. I fired it up today for 1 hour. From a half hour to a hour the oven kept the same temperature readings with my laser temperature gun. It reads around 1050 at dome and only 450 on floor. Does anyone know why I can't get the floor to the 800 degrees that I need to make my 90 second pizzas?
  • Lburou
    • Dec 2010
    • 1165
    Re: Propane (gas) Pompeii won't get up to correct temperature
    Two things:
    1) You may not be totally cured yet, driving the moisture out may require a few cool cycles to allow the moisture to equalize and then get eliminated by the next heat cycle.
    2) Safe use of gas to heat the oven is a precise and tricky process, one that the ownership of this board doesn't condone. You will have to find another place for advice about using gas to heat your oven.
    HTH
    Lee B.
    DFW area, Texas, USA
    • Ken524
      • May 2007
      • 1655
      I hate to ask... did you insulate under your floor? If so, what material did you use and how much?
      Are you heating ONLY with gas? It would take a huge amount of propane to bring a Pompeii up to full heat. Where are the burners located? You can't beat a wood fire for speed and temperature. I would ditch the gas altogether and use wood. I promise you, I can get my WFO oven fully heated and ready for pizza faster (and cheaper) than any gas oven. And wood is a heck of a lot safer.
      Ken H. - Kentucky
      42" Pompeii
      • brickie in oz
        • 3445
        Well said Lee.
        The other thing is propane seems to leave a lot of condensation, if you use a propane heater inside a room the windows always fog up.
        • Lburou
          • Dec 2010
          • 1165
          Wish I had said that about the insulation under the floor Ken....But moisture, from the propane or residual, in the oven floor was my first thought.
          To illustrate how fast a Wood Fired Oven can get to pizza temperature, I went to town a few days ago (a 25 minute drive each way and about 25-35 minutes at Home Depot). I lit the fire as I left for town. I called to check on the fire and the paper had not burned....So My good wife re-lit the fire. She added some wood after it took off and the dome was 1050 F and floor was 820 F when I got home, that was about 65-75 minutes after she re-lit it. That time to pizza temp is a record for us. I burned the first pizzas big time , won't try to cook at that temp again.
          Lee B.
            • 9211
            Try a little semolina flour cast into the centre of the floor before placing the first pizza. It should turn black in 3 secs. It is the best floor temp test IMO
            • Ken524
              • May 2007
              • 1655
              This thread got quiet. I figured we would have heard back from the original poster. Hope he didn't hurt himself with the propane.
              Ken H. - Kentucky
              42" Pompeii
              • Neil2
                • Oct 2006
                • 1374
                Here is a picture of him:
                • Ken524
                  • May 2007
                  • 1655
                  Ouch. I don't wish that on anyone!
                  ss0357, You out there? I'm sure we can help you.
                  Ken H. - Kentucky
                  42" Pompeii
