Hi... im cooked.
  • cooked
    • Oct 2011
    • 9
    Hi... im cooked.
    Hi there, just joined your awesome site. tomorrow the builders start building a wood fire oven in my kitchen. it will be built outside but the oven door will be on the inside. i live in Hungary and am struggling to convey all ive learnt from this site to the builders (i dont speak Hungarian). lets see what they come up with as they have assured me it will be able to cook all sorts
    i cook on a open wood fire whenever i can but this will be my first proper oven... cant wait.......
  • Lburou
    • Dec 2010
    • 1165
    Welcome
    Sounds like you have a big job in front of you.
    Your situation is challenging because of the language difference, but additionally, I'm sure your builders know how to build an oven that is NOT as efficient as the oven featured in the free plans from this site. Be sure you understand the requirements of the pompeii plans and follow the progress day by day to be sure each step is according to the plans -show them the pictures from the plans, that will help them understand what you want.
    One big issue will be designing the flu location as you vent the smoke away from inside your house. Be sure to keep the door height to 63% of dome height and enough flu area to keep the smoke outside.
    Good Luck
    Lee B.
    DFW area, Texas, USA
    • GianniFocaccia
      • Jun 2009
      • 1645
      Re: Hi... im cooked.
      Good advice from Lee, for sure. If there's anything you want to be absolutely clear about with your builders, it's NOT to scrimp on insulation or use questionable substitutes.
      Good luck with your most valuable endeavor.
      • cooked
        • Oct 2011
        • 9
        thanks for the help guys. - the builders have been delayed for who knows what other reasons other than cold and rain. things are a dragging, but they promised it will be finished by saturday....lets see!!! i will post pics etc of the build in another thread. (if i can figure out how to attach pictures)
        as my maths is also quite bad, maybe someone can help me out.... the oven door will be 57.5 x 49.5cm thats roughly 19.5 inches high. would i be right in saying the oven height would need to be 62cm (24.5inches) to be the required 62.5 % ratio?
        your help will be greatly appreciated..... thanks in advance
        • cooked
          • Oct 2011
          • 9
          this is the door of the oven.....
          • cooked
            • Oct 2011
            • 9
            mmmmmm - that pic upload did not work - ill try again.....
            • cooked
              • Oct 2011
              • 9
              third time lucky....
              • brickie in oz
                • 3445
                Hi Cooked.
                If you have trouble communicating with your builders it may be best to draw what you want, most people can understand a drawing in any language.
                • cooked
                  • Oct 2011
                  • 9
                  Hi Cooked.
                  hi... yes i have given them loads of pics etc. i just really need to find out if my maths is correct - eg. is 49.5cm - 63% of 62cm just need confirmation before i make a big booboo. they have promised to start laying the bricks tomorrow. the concrete foundation was laid out yesterday. the foundation is about 20cm thick and is directly laid onto clay soil. (the room is lower than the ground surface).
                  so please - if anybody can confirm my maths
                  • brickie in oz
                    • 3445
                    Work backwards.
                    Your oven internal dome height is 620mm * .63 = 390mm for the top of the door.
                    • cooked
                      • Oct 2011
                      • 9
                      i cant work backwards as my door is 49.5cm high. therefore i need to figure out how high my dome should be built.
                      • brickie in oz
                        • 3445
                        Sorry, I did read that but forgot.
                        The oven internal height should then be 785mm. (thats a very high oven in my opinion)
                        785*.63= 495mm
                        • cooked
                          • Oct 2011
                          • 9
                          thank you Al.
                          • cooked
                            • Oct 2011
                            • 9
                            Hi Cooked.
                            you would think so !?! the oven is still not complete and even after showing them tons of pictures ,they still cocked it up.
                            ...anyway when its done i will modify it myself
