Re: Hi all from Aussie
I have used Hebel a couple of times between supporting slab and oven floor. One problem is that if placing wet mortar on top of it, then it will suck the water out of the mortar so fast that it makes it difficult to keep the mortar plastic. It does give you a nice flat surface to work over though, so you really don't need mortar. It is about a third the density of standard concrete so isn't a bad insulator, but I don't think it"s as good as vermicrete. Another advantage over vermicrete is that it is dry, so you don't have the extra problem of eliminating the water from Hebel. It is also way more expensive than vermicrete. I used the Hebel Power Panel ie 5mm steel reinforcing rods cast into the middle of the panel, in the floor of my mobile. I was try to get a fairly strong floor that was also an insulator. It has cracked a fair bit, but because it's in a steel cradle all is still ok. I don't know if it cracked because of the weight, the heat, or the big speed bump I hit at speed when I forgot I was towing an oven.
That is way cheaper than I could get it. Don't forget that Hebel is made from Portland cement and your floor will be pretty hot. If it were me I'd put a 1" layer of vermicrete between the hebel and the floor bricks to take the sting out of it before it hits the Hebel.
Originally posted by robertjusher
View Post
