Newbie from Montreal
  • MarcoMatteo
    • Jun 2013
    • 1
    Hello
    I've been wanting to build a brick oven for years, and finally am going to do it. Going to build it at my parent's house and then when I have enough land of my own, going to move it there.
    I have three main questions. Definitely, the first of many, many to come
    1) As far as insulation goes, if I use firebrick as the main "building blocks" of my dome, do I still have to use a cement/vermiculite ratio as the outer layer? Can the outer dome simply be the brick and the mortar? Is the cement/vermiculite mixture the smooth surface you see on many of the pictures?
    2) Isn't the use of all the "-lites" potentially hazardous? I understand they're used as a layer for heat retention, but does it give off any hazardous fumes, seep into whatever is cooking?
    3) For the structure, can steel be incorporated? I'm an ironworker/welder and definitely want to incorporate a steel structure into my oven.
    Thanks!
  • Bert
    • Apr 2011
    • 102
    Re: Newbie from Montreal
    I can see a fantastic oven door in your future, given you have experience with iron work. Good luck with the build! Bert
    Fail to Prepare...Prepare to Fail!
    • brickie in oz
      • 3445
      Originally posted by MarcoMatteo
      Hello
      Won't happen as moving ovens that have been fired really doesn't work.
      • Laurentius
        • Nov 2010
        • 923
        Al,
        Enjoy nature! Inform us on your moving in the Outback, not moving ovens.
