Hello
I've been wanting to build a brick oven for years, and finally am going to do it. Going to build it at my parent's house and then when I have enough land of my own, going to move it there.
I have three main questions. Definitely, the first of many, many to come
1) As far as insulation goes, if I use firebrick as the main "building blocks" of my dome, do I still have to use a cement/vermiculite ratio as the outer layer? Can the outer dome simply be the brick and the mortar? Is the cement/vermiculite mixture the smooth surface you see on many of the pictures?
2) Isn't the use of all the "-lites" potentially hazardous? I understand they're used as a layer for heat retention, but does it give off any hazardous fumes, seep into whatever is cooking?
3) For the structure, can steel be incorporated? I'm an ironworker/welder and definitely want to incorporate a steel structure into my oven.
Thanks!
Thanks!
